Rim size suggestion
georgeperez38
Rim size suggestion
Post by georgeperez38 »
Hi everyone-
I have a 93 Legacy L (FWD) with the stock 14" rims. I want to upgrade. From experience, would 17" rims fit without any additional mods? And on the issue of ride, would there be a noticable ride difference between 17" tires to 16" tires?
mTk
no title
Post by mTk »
I had 17s on my 92 when it was fwd. They fit fine w/o additional modifcation.
The ride won't be much different between 16 and 17. I say go w/ a good looking set of 17s, however people here will tell you that 17s are too heavy and bad for your car etc.. stock WRX wheels will be recommended, but they are fugly :)
MK
1992 BC672 AWD 5MT
mTk
no title
Post by mTk »
7 or 7.5" width is recommended, offest should be at least 48mm
MK
1992 BC672 AWD 5MT
georgeperez38
Thanks for the info MK.
Can you E-mail off list @ georgeperez38@cox.net
Have a quick question and site to send you to see if these rims are the right ones.
MY92
Post by MY92 »
17's are heavy unless they are RG's or TE37s :)
I've got a nice set of 16x7+47 Advan RG's and they weigh a good 2kg's lighter than the factory 15's with tires.
John
http://www.cardomain.com/ride/560635
BAC5.2
Post by BAC5.2 »
17's are generally thought to be the best size for Autocross. Small enough sidewall without being TO short, and without being TO heavy.
The only downside is going to be the 45 series sidewall. That's not going to be the most comfortable sidewall you can have, it'll be a pretty harsh ride.
17's are too big IMO for a car that had 14" come stock.
Turbo legacy is difference since it came with 15" stock. But that's just my opinion.
LegacyT
Post by LegacyT »
Sorry to Hijack, but does anybody know the weight of Legacy GT rims and stock Legacy turbo rims? Just curious.
Thanks,
Mark
MY92
Post by MY92 »
about 16kg w/ tire.
John
georgeperez38
So what I'm hearing is that 17" might not be a good idea. And that 16" would be better?
MY92
Post by MY92 »
It is whatever you make of it, function or form?
Function first myself.
John
georgeperez38
:D
One last question then. I'm looking at this rim size 16X7 5-100 45S. Tire size 205/50R-16 91V . Will this combination work for 93 Legacy L Sedan?
Thanks.
MY92
Post by MY92 »
Yes
John
scottzg
Post by scottzg »
perfect!
Just make sure that the offset is 50-58mm. Otherwise it's kind of hard on your wheel bearings and might look funny.
MY92
Post by MY92 »
Nothing wrong with my 47 offset. Sits perfectly flush with the body.
John
georgeperez38
Cool. Thanks guys. I'll go ahead and run with what I have. Just out of curiosity, have you guys (and gals) had an problems with wheel bearings after 160,000 miles?
Thanks for your help everyone.
Original wheel bearings here with slightly incorrect offset since 110k.
