crazy blinkers
crazy blinkers
After the swap I noticed that my blinkers don't work. These should always work when the car is on right? This has happened before, but it was only briefly. Another thing I noticed is the car likes to die sometimes depending on how quickly I decellerate. Again could this be related to still using the 4eat ecu?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
well on the pre-face the blinkers and parking are separate. but ill go check all thos other things. I didnt cut anywires aside from the gear indicator wire. I hope it's a fuse, knowing my luck it would be, but then I'll be wonrderng why it blew in the first place.
petridish38
One day while it was raining I had my blinker on waiting to turn left... Then next to me I saw this guy trying to push his car off the road as it was broken down. I decided to get out and help.THAWA wrote:I hope it's a fuse, knowing my luck it would be, but then I'll be wonrderng why it blew in the first place.
Anyways.... the point is, I turned my hazards on before I got out and left the blinker on as well which caused the fuse to blow. Hopefully this is what happened in your case.
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
well it was a fuse but i didnt do any of that stuff, just stopped working, if it blows again i'll investigate.
okay well it happened again. So now is the time to figure out whats causing the problem.
oh wait I think i found out what it is. the reverse lights are on the same fuse as the turn signals right? I saw it said "back turn"
okay yes that was the problem, I believe
. I had the wires that would normally be attaced to the shift selector frayed, loose, and open, and I think it was grounding through the chassis, or exhaust, or tranny or engine or something who knows which overloaded the fuse and pop. So I just snipped em off and taped them down, so far so good
