vf 35
91scoobiesubie
vf 35
info does any one have it will it work
Matt Monson
- quasi-mod-o
The VF-35 could be compared to a modern version of the VF-24 with upgraded bearing design. It uses the same compressor at the VF-30, but uses the smaller P15 exhaust housing. It makes for a quick spooling turbo that, like the VF-24, would be a really good match for an automatic Lagacy turbo. It will run out of steam up top, but unless you have headwork, you won't be running past 7000 rpms anyways. It will have a very very solid midrange. It will mount like any of the late model VF series turbos, which means it has a straight inlet and not the 90 degree bend of the older turbos...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
91scoobiesubie
