The Torque Output of an EJ22T?
LegacyT
Post by LegacyT »
How is it that our stock EJ22T powered Legacys put out 181 ft/lbs of torque? 20ft/lbs of torque more than HP. This is very unusual for an engine? Is it the turbo? :P Also at what RPM is the torque at 181ft/lbs.
Thanks,
Mark
The motor has more displacement then say the WRX.....so the amount of torque is going to be more......which is why this motor is such a good platform for monster motors.....:D
DLC
Post by DLC »
Turbo engines nearly always have more torque than HP.
That 181lb/ft is at 2,800rpm.
Legacy Central
LegacyT
Post by LegacyT »
But how is it that the peak of the torque curve is at 2800 RPM where the turbo is just starting to spool up?:?
Thanks,
Mark
Aaron's ej22t
Post by Aaron's ej22t »
Because our turbo's are very small, and they designed the turbo to spool quickly for good low end power.
-aaron :o
EDIT: hey morgie, my mistake, it is not 2800 rpm. mine is at stock boost level (8.7psi) and a k&n filter w/ snorkus removed. mine is spooled by about 3300. :o
92 Legacy Turbo \ 5MT \ Silver
morgie
Post by morgie »
at 2800rpm i can tell you that my turbo is not pushing verry hard, at about 3-4psi .. 8-9-10 psi is reached at about 3300-3500rpm ! :\
morgie
'98 4Runner V6 Manual 4x4.
RaZor
Post by RaZor »
With my costum downpipe,the turbo reaches full boost(10 psi) at ~2900-3000RPM
91Turbo
Post by 91Turbo »
I thought it was 2600?
91 Legacy Tubo
Pearl White-stock
RaZor
Post by RaZor »
Well...I'll have to check it out again then!!!! I'll let know know the exact thing!!!:)
DLC
Post by DLC »
I'm just going by the Subaru specs, so don't shoot the messenger :P
Legacy Central
morgie
Post by morgie »
the spec is 181lb-ft @ 2800rpm from subaru ;)
morgie
91Turbo
Post by 91Turbo »
sorry about that i always misread stuff on edmunds
91 Legacy Tubo
Pearl White-stock
91Turbo
Post by 91Turbo »
does anyone have a torque curve for a leg turbo?
91 Legacy Tubo
Pearl White-stock
-K-
Post by -K- »
Turbos almost always have big torque. That just keeps on going, flat enough to build a house on. You might not get full boost untill 3000 rpm but even at 0 psi (no vac) the engine doesn't have to suck air. That makes a big difference. Turbos also don't need to run a big cam. You get a mild cam that makes good torque down low and make up for it going flat on top end with boost.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
