My alternator belt is squeeling
LegacyLS90
My alternator belt squeels when i turn the car on, and when i hit the brake it also squeels
. Is this normal? Also when i hit about 3000 r.p.m.'s, my engine starts to make a clicking noise. I tightened all the bolts and nuts around the alternator and belt, but it still squeels. Do you think I need a new belt, or maybe just some belt spray?
Danny
what bolts did you tighten/loosen.
You need to loosen the clamping bolt and pivot bolt a little.....then use the adjuster bolt.......if you did all this and it still squeals....replace belt.
Thanks Morgie.......yeah picture is worth 1000 words.
LegacyLS90
Tool from subaru......
chain wrench....however I don't recommend using one as it can damage the pulley.
boostjunkie
If you've tightened the belts and there's still squeeling going on, it's most likely one of your accessories that's going kaput. I had the same problem with my alternator. The damn thing would keep squeeling so I'd tighten the belt up, spray it down with belt dressing, and the damn things would squeel again the next day. A few weeks later my alternator went out.
Are there any intermittent power steering loss? Unusually hard starts some mornings?
LegacyLS90
