Backfire..
BAC5.2
Backfire..
Post by BAC5.2 »
What causes a backfire?
Right now, I get a "puff" and a pop when I shift (like a muffled backfire). I'm wondering if, when I upgrade my exhaust, will I backfire constantly on shifts?
I always thought a backfire was gas hitting the hot cats.
Matt's car doesn't backfire much with the test pipe, but Jason's car backfired like a son-of-a-bitch as I recall.
So what causes it?
THAWA
Post by THAWA »
I do believe thats what causes it, or just fuel being burned outside the combustion chamber.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Any hot condition in the exhaust combined with excess fuel. Severely retarded ignition could do it, but you'd know that. A bad gasket could possibly do it if you were running rich and had a sudden introduction of O2.
stillkckn
backfire source?
Post by stillkckn »
In a fuel injected, computerized, modern system, backfires should be non-existent. Among other things, I would think that any CAT matrix would take unkindly to that sort of abuse. Even if there is extra fuel getting into the exhaust, somehow (valves, stuck injector, etc.), you'd also need some source of oxygen getting into the exhaust, somewhat tricky on a pressurized system. Otherwise, the likely source is not just fuel, but rather fuel/air mix, getting dumped, in large enough spurts to ignite.
Sometimes, sounds can be misleading. Are you sure it's a backfire?
In the day, everything ran rich, and excess fuel was used to cool exhaust valves. At $2.50 a gallon, you don't see a lot of that anymore.
Jeff
legacy92ej22t
Post by legacy92ej22t »
Backfire=bad , afterfire=good , right?
Backfires come back through the TB, don't they?
Anyways ya, I rarely get afterfire but I do sometimes when I'm at wot and either shift or engine brake.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Mine pops a little at the start of loaded engine braking when cold.
91White-T
Post by 91White-T »
Mine backfires all the time since i pulled the cats. It's probably unburned fuel hitting hot turbine.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
georryan
Post by georryan »
Mine pops once in a while between shifts. Mainly 1-2 and 2-3. I've never heard it from 3-4.
I didn't use a gasket for the downpipe, though. I used the BEP as the gasket. So far my car doesn't seem to pop any more often than it did when the old exhaust was on there.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
nzKAOSnz
Post by nzKAOSnz »
So the pops etc arnt bad?
***ITS CLEAN! :D*****
dzx
Post by dzx »
Does your bov vent atmospherically?
///M
'93 Legacy SS - part out
BAC5.2
Post by BAC5.2 »
Yep. HKS Super Sequential. I'm going to buy the recirc kit though, I think.
legacy92ej22t
nzKAOSnz wrote:So the pops etc arnt bad?
Nope, they're normal. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
dzx
Post by dzx »
probably just runs rich between shifts. Shouldn't be a problem at all.
///M
tris91ricer
Title Whore
Post by tris91ricer »
when I had a DTM on my 91, I had a kind of popping on engine brake.. that was when I'd downshift to a lower gear, and just let the clutch out. I thought it was kinda cool. :lol:
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
