So, I'm building a bike with all of my spare parts that I've gathered over the years.
Here's the specs:
-17" Stumpjumper S-works (2003 Pro frame, 3lbs)
- Surly Instigator Rigid Fork (actually got this off of a buddy of mine for $20 bucks)
- Shimano XT cranks with an XT bottom bracket
- Alex TD-17 wheelset with a ghetto-rigged, broken cassette single speed (break apart the cassette, space out the hub and put the desired ring on there, flank it with 2 larger rings to act as a chain guide).
- Nokian NBX 2.3" tires (not installed yet)
- STS headset (I was going to use my PIG, but I don't have a crown race for either of the two that I have, so I'm getting the STS for free off of my buddy).
- KOSKI stem, bars, and seat
- Avid SD-3 Levers (customer donated them to me
- SALSA Pro-ring 32T unramped front chainring.
- Un-ramped, 16t rear cog.
- Promax Mechanical Disc brakes
- Hingulator (a chain tensioner made from a door hinge and a derailuer pulley. Pretty ghetto).
I think that's about it. SUPER simple, durable, and light.
Sans the fork/front wheel, the whole setup as you see it weighs 11 pounds, that's about the same as my whole rear wheel from my downhill bike. Target weight is 20 pounds or less, for as little money as possible.
So far, I've spent $31 on the whole bike, and I don't see myself spending any more (other than a new chain).
WOOO! FREEBIES!
