I have some almost new struts and springs from a 2003 Impreza RS and want to put them on my latest a '91 L+ Legacy. The legacy springs do have some taper and are smaller at the top.
This car will mainly be used on the road so ride is important and I wouldn't mind it being a bit lower. Do I buy the new top hats ???
I also have the old springs from my '95 Impreza coupe would these be usable?? Or possibly use the springs from the RS ??
AL
al@iwtu.net
2003 RS struts and springs for a '91L+ Lecacy?
You'll definitely need new top hats in the rear.
It may sit a little low with the impreza springs.......but I think others have done it with decent success. There's a few threads out there with more info.
I think I am going with the struts and springs from the RS with new top-hats in the rear. A 1.5" drop won't bother me and I am not going to push this car as far as handling. My Impreza that is for sale has AGX struts with Ziggen springs and most of the suspension and brakes came fron a Turbo Legacy wagon,
Hi,
It is a '95 Impreza coupe with a almost new (2200 miles) STI turbo shortblock using the Turbo Legacy heads(reconditioned) ,turbo and electronics.
It has a '99 Legacy GT transmission, 12lb Chromoly flywheel, ACT clutch, Liberty AWIC, STI shifter, short throw, Turbo Legacy suspension and brakes, AGX struts, crossdrilled rotors, high cap fuel pump, cold air intake, SuperSprint stainless exhaust (lifetime warranty) sway bars, strut bars, ACT clutch and more. If you e-mail me I can send you pictures and complete list.
over $14,000.00 invested 8,000.00
al@iwtu.net
al@iwtu.net
