dash/running lights
gordini
dash/running lights
Post by gordini »
hi guys,
i have a small problem that i could use some help with. I had an electrical short under the dash and ever since the dealer fixed it, both my dash lights and the rear running lights dont function. so i'm guessing its the fuse but i'm not sure which fuse covers these. its a 91 ss, so if anyone could help out that wiuld be great!!
thanks alot guys.
There are two fuse boxes.
The one with the light info you want is at the lower driver's side kick panel on the left.
gordini
Post by gordini »
thanks but what i need to know is which fuse is for the dash lights and which is for the rear running lights. :?:
This info is for my 90 legacy....but should be the same for yours.
fuse 05 - Tail light, Clearance light
fuse 09 - Illumination brightness control
fuse 12 - Brake light, horn
fuse 15 - Meter (I'm assuming this is combination meter...which is instrument gauge.)
Those are all the ones I can find that deal with lights.
It should say on the fuse panel cover what fuse is what....and for sure in the owner's manual.
