Battery Relocation...
BAC5.2
Post by BAC5.2 »
What's the scoop?
I've gotta do it, so I want tips.
Do I need to fuse it? How should I connect up front to the stock terminal areas? Ground to trunk? Where?
ALL info is helpful :)
Brat4by4
Stratified
Post by Brat4by4 »
Try a search n00b!
Grounding is easy to the bolt for the rear bumper beam. It's under a plastic cover below the carpet.
