ECU Reflash
J-MoNeY
ECU Reflash
Post by J-MoNeY »
Have any of you computer gurus ever considered the option of a reflash of our current ECU so that it could run with 10-13psi without the aid of a boost controller?
98 LGT
THAWA
Post by THAWA »
how is that possible?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
J-MoNeY
Post by J-MoNeY »
My friend got his 04 GTI reflashed. Pretty much they just took out the old ECU and reprogramed it to different perameters so that it could run more boost with all adjustments already made to compensate for it. Then he just pluged it back in. I think he was around 11psi before. Now he's at about 20-23psi.
98 LGT
ultrasonic
Post by ultrasonic »
Something like Cobb's AccessPort or AccessECU...
http://cobbtuning.com/wrx/accessport.html
http://cobbtuning.com/wrx/accessecu.html
...a product or solution like this for BC/BF turbos would be really great.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
THAWA
Post by THAWA »
okay I understand the electrical part, but was wondering how you can run a higher psi than normal without any form of boost control.
georryan
Post by georryan »
Milehi can do it. He said he could do it for a couple hundred bucks to people on this board. Try a PM to him.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
J-MoNeY
Post by J-MoNeY »
THAWA wrote:okay I understand the electrical part, but was wondering how you can run a higher psi than normal without any form of boost control.
I would Image it alows the stock boost controller to allow higher boost levels to be acheived.
98 LGT
mTk
no title
Post by mTk »
What j-money said, setting max boos tin the ecu will let it learn what it needs to do to achieve that boost and set timing and fuel accordingly.
MK
1992 BC672 AWD 5MT
THAWA
Post by THAWA »
so it still uses some kind of boost control?
mTk
no title
Post by mTk »
Of course, the stock boost control solenoids.
MK
1992 BC672 AWD 5MT
ultrasonic
THAWA wrote:so it still uses some kind of boost control?
Sure, the stock boost control solenoid, under command from the ECU, with reflashed parameters. Ought to work.
Someone... crack the code!
-steve-
03 Legacy L Wagon
rsstiboy
Post by rsstiboy »
the Link ECU uses the stock boost solenoid, I can program mine on the fly! at the moment it spikes to just under 20psi then settles on about 18psi by redline.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
azn2nr
Post by azn2nr »
the cobb accessport is way cool but when i talked to them they said unless they see a bc bf market for it and big time they arent even gonna mess with it. kelly has a leg up with his ecu hes makin for this sort of thing
-jason
J-MoNeY
Post by J-MoNeY »
rsstiboy wrote:the Link ECU uses the stock boost solenoid, I can program mine on the fly! at the moment it spikes to just under 20psi then settles on about 18psi by redline.
Damn Auzies. :lol:
98 LGT
DLC
Post by DLC »
The stock ECU can NOT be reflashed. In order to reprogram it, you have to remove the ECU, solder in a socket, flash a new chip with the original rom and reinstall. I only know of one that's been done.
Legacy Central
legacy92ej22t
Post by legacy92ej22t »
So would that be considered a piggy-back?
Has anyone ever heard what kinda price tag Kelley's talking about for his engine management?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
free5ty1e
Post by free5ty1e »
Is there a possibility that a performance shop that does dyno tuning might be able to reflash our ECUs? There's a good one close to me that has a 9 second Supra...I'm gonna ask them about a reflash.
-Chris
91SS 4EAT stock, 200k mi
91l-t
Post by 91l-t »
there's a shop in Toronto, Ontario, that can dyno and tune our ecu's. I think it's around $700.00 canadian. Japan Automotive
91 legacy l blue ej22t
92 ss auto (wife's)
97 outback ej20 13.7 @ 97mph :)
