cheapest way to lower 94Ti wagon
The Scooby
Post by The Scooby »
ok i got a set of front and rear struts, my Ti wagon has air suspension on it and i want to lower it.
so i picked up the struts and stock springs, i dont want to cut.heat the springs because i dont watn that dumb bouncy ride,
any ideas??
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
BAC5.2
Post by BAC5.2 »
Get new springs. $172 for some Tein S-Techs.
Otherwise cut the springs.
THAWA
Post by THAWA »
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
scottzg
Post by scottzg »
pop your tires.
You probably wanna steer away from the stechs because they are a progressive spring and the stock shocks are linear. Good choice to stay away from cutting, there is some tapering of these springs so the diameter wont be the same if you cut, also, the coils are not all the same width and you will load the new fresh cut tip.
Check out the stickied suspension info compendium.
2.5rs springs off nasioc would be a cheap option.
You will need some rubber things and some nuts and some top mounts too- this might be more expensive than you think. Be aware that the rear springs are different in 90-91 and 92-94 models.
The Scooby
ya i know the differences, i worked at a subaru wrecking yard here in seattle for a while and know quite a bit about bodystyles and such, just nothing about the interchangability of springs.
Shean
1986 GL wagon
EJ'ed and Lifted
The Scooby
ok i just got a set of 03 WRX wagon springs and was wondering if they will work on the legacy struts?
i paid $40 for them is this a good deal?
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
You work at Aarons? What's a Ti?
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
The Scooby
i used to work at aarons, my last day was last thursday so i would have a week to pack for college.
a Ti was the outdoor wagon, the airsuspension gives you a 4inch lift for offroading, full skid plates, different interior, side decals etc etc.
1986 GL wagon
EJ'ed and Lifted
LaureltheQueen
Spelling Nazi
Spelling Nazi
cool! never heard of one of those
eastbaysubaru
Post by eastbaysubaru »
It really has skid plates? If so, could you take some pictures of the undercarriage?
-Brian
'04 PSM FXT
LaureltheQueen
Spelling Nazi
Spelling Nazi
if you're dropping it while you're still in town, I'd love to lend a hand or if it's not too much hassle, at least get a look at the air suspension setup
The Scooby
ya i wont be doing the suspension swap before i move, it will be sometime while im attending college, just dont have the time now.
but again, does anyone know if the rex springs will work??
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
THAWA
Post by THAWA »
someone is going to tell you to remove the picture in your sig
LaureltheQueen
Spelling Nazi
Spelling Nazi
wrx springs will fit... bu the spring rates are different, because the wrx is a lighter car, and definitely doesnt way as much in back. Dunno how it'd look. You could TRY it.
THAWA
Post by THAWA »
LaureltheQueen wrote:doesnt way as much in back.
laurel, I'm shocked!
