Magnaflow
Magnaflow
Ok i really hate this one noise that my magnaflow does when i let the gas go at high rpms it makes a weird high pitch noise. what is that?
1990 Legacy Sedan LS AWD 5-MT 162k miles Slate Metallic (Sold to Brother)
1992 Legacy SS AWD 5-MT 180k miles Mica Black
BAC5.2
Exhaust leak.
My magnaflow on my CES system doesn't make any noises like that.
you took off all your heatshields, from the headers back?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
BAC5.2
Replace the O-pipe while your at it. Yours is probably worn out.WRXdan wrote:Sounds like a worn muffler bearing. Pepboys stocks them.
Good point...that is a commonly skipped step. The last, most common skipped fix is replacing the sphincter valve right before the muffler inlet. The valve is never replaced like it should be.BAC5.2 wrote:Replace the O-pipe while your at it. Yours is probably worn out.WRXdan wrote:Sounds like a worn muffler bearing. Pepboys stocks them.
92 Turbo Legacy 4EAT
02 WRX - lightly modded (Gone but not forgotten)
I don't recommend the practice of replacing the muffler bearing on an old muffler. For the cost of the new OEM-style bearing plus the labor of packing it (not to mention the special exhaust-safe technetium grease you have to use to do the job right), you might as well get one of the new modern mufflers that use sealed ball bearings. They usually come with the bearing already installed. The end result is a setup that requires less frequent maintenance while also providing less friction.
Oh, and a neat tip -- if you do decide to replace the bearing, or if the new muffler you get doesn't already have the bearing installed, you can use turn signal fluid as an assembly lube to help slide the bearing in place without putting too much force on the muffler's pinion gear.
Ceramic muffler bearings? I'm skeptical. Back during the energy crisis a lot of manufacturers experimented with that kind of stuff. They worked okay when the cars were stock, but any power-increasing modifications at all proved deadly to the fragile material used in the bearings. Trust me, you don't want pieces of shattered muffler bearing flying around in there, getting trapped in the gears and flying out the tailpipe.
You're forgetting that in the 70's the fuel was 20% corn husk oil. This oil would break down the ceramic material. Today's gas has mineral oil, which is less acidic then CHO.vrg3 wrote:Ceramic muffler bearings? I'm skeptical. Back during the energy crisis a lot of manufacturers experimented with that kind of stuff. They worked okay when the cars were stock, but any power-increasing modifications at all proved deadly to the fragile material used in the bearings. Trust me, you don't want pieces of shattered muffler bearing flying around in there, getting trapped in the gears and flying out the tailpipe.
