vf34
azn2nr
vf34
Post by azn2nr »
how easy or hard would an instal of this turbo be
-jason
THAWA
Post by THAWA »
pretty hard, since it's not an intercooler :)
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
rsstiboy
Post by rsstiboy »
its pretty much a bolt on, its the intake that will need modification, and oil and water lines...
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
-K-
Post by -K- »
If you don't have an intercooler it would be best to do the turbo and IC at the same time. Plus what would you do with a VF34 and no IC? If you go with a Subaru IC (early WRX or Air to Water) the turbo to TB pipes would bolt right up. If you go with a front mount for a WRX it would work with a little modification.
You need to get a 90 deg inlet for the turbo made.
Oil and water lines fit different. Oil at least. It's bolt in for a WRX right? If so the oil and water lines from a WRX might work??? That needs to be looked into.
The VF34 should bolt to the up pipe and down pipe fine.
rsstiboy might be able to help source these things because there are plenty of guys doing the swap over there.
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
legacy92ej22t
Post by legacy92ej22t »
The coolant line that comes from the coolant fill tank is different on the WRX because the WRX's coolant tank is over by the PS pump.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
rsstiboy
Post by rsstiboy »
if you guys want any turbo's like these I can get them fairly cheap and can send them over, they are selling over here for $1100au with gaskets etc.... could be shipped over there, but there may be somebody on nasoic that can get them direct to US from japan, that way would work out cheaper for you guys, wait to see what happens over the next 6 months with the US-Australia free trade agreement.
azn2nr
Post by azn2nr »
i found one on ebay for 600 bucks. i just didnt want to spend another 600 on instal fees and try to attempt to do it myself
-jason
legacy92ej22t
I see used VF34's on nabisco all the time. They usually go for about $400.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
free5ty1e
Post by free5ty1e »
any VF-34 turbo will bolt right up to the stock up-pipe and exhaust flanges, like a 16g? That is good to know. How do these turbos compare to the 16g, and how do they compare to the stock turbo/t-bird hybrid turbo?
Also, is this an RHB5 we're talking about...?
-Chris
91SS 4EAT stock, 200k mi
azn2nr
Post by azn2nr »
nabisco???
-jason
legacy92ej22t
azn2nr wrote:nabisco???
Hehe, sorry. Nabisco=NASIOC. I guess I take for granted that everyone knows that slang for it. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
azn2nr
Post by azn2nr »
did the vf34 come in a us wrx also do the vf39's bolt up too.
-jason
