THEY FIT!!!!!
THEY FIT!!!!!
Did a test fit.
17" x 7.5" +48mm RAYS Gram Lights
Tires were: 225/45/17 Falken Azenis (which are pretty friggin wide)
Do they fit?
About 10mm strut clearance on the drivers rear. A LOT of clearance on the passenger side rear (is that normal?)
No rubbing. They fit the wheel wells PERFECTLY.
Pics:
I LOVE how that looks!
Do they fit?
Pics:
Oh, I should add, when turning, they almost rub the fenders, that's why I say they fill the wells really well.
The guy whose house I was getting aligned at said he was half expecting me to stop right there and say they rubbed. I didn't hear a single noise from them, so I assume they were fine. A narrower 225 width tire would be GREAT. They stick out slightly from the fenders, so maybe a 49 or 50mm offset would be slightly better.
The suspension would arc slightly, and the tire would tuck into the fender. Roll the lip, and they'll just barely clear I rekon.
Most of the problem was with the tire width. The Azenis is a WIDE tire, almost a 245 actual width. It's the widest 225 you can buy. A REAL 225 tire would fit MUCH better.
The front left tire was on the rear of my buddies WRX. It was almost 1 full inch Toe'd IN for about 200 miles. He just didn't have the time to correctly align them. He said you could measure the tread wear with a stop watch. Good thing those are CHEAP tires (comparatively) .
You should see the Left Rear of the Prada Spec 2 on his 05 Legacy GT. It was the front left on his WRX, which was corner weighted at 1000lbs (eek!). The tires were BRAND new when he went to the Dragon. It is completely bald less than 1000 miles later.
Apparently, those wheels are only appealing to Subaru guys. My mom and dad don't like them, and my girlfriend said, "They look hideous on your beautiful car."
Oh well, I like them. They are contenders for when new tires come around. I hope I can get my RE92's to last until I can afford the $1000 price of the Gram Lights and the $500 price of some Kuhmo MX's or Toyo Proxes 4.
yeah, whats up with that?kidatari wrote:Is it me, or are those Azenis a touch on the bald side?
BUt yeah, I can't say I care much for the wheels. Spokes are too small for my liking, but hey, it's not my car.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Damn, those look hot! I love the way the stance looks, it just has a really aggressive look with the bigger wheels and WIDE tires.
No, Phils car isn't lowered but his rear end is lower stock then mine. We had our cars side by side and Phils was noticably lower in the rear.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I like the rims and think they'd look great on my even darker blue car, but I'm torn as the gold will definitely reduce the sleeper look. Aren't Azenis always bald?
If you get the lips rolled you can have them take care of the rust at the corners too. It shouldn't be too bad.
What do the rims weigh and do they come in silver 16"?
Gram Lights are LIGHT. The wheels and tires weighed slightly less than my WRX wheels and RE92's.
I am going in for an estimate on my rust, probably tomorrow. I'll have them roll the fenders at the same time.
I think the wheels would look great in a silver/gray kind of color.
They are only available in 17 and 18, but there are a lot of clones out there that would probably be available in a 16.
My next tires WILL be 225's. Nothing screams "don't fuck with me" like 8.85" of rubber at each corner of a turbo AWD car.
Are those Gram lights, or are they clones?
Is that car lowered? Why does the front end sit so well compared to my car?
Thats how legacy's (and most subarus for that matter) look stock.
How lowered?
I am looking at the rota's, i'll have to see. It's hard to justify $1000 on the Gram Lights.
It's a few inches all around. Checl out the picture sections in: http://homepage.mac.com/michaelkuhn/ for before and after.
MK
MK
1992 BC672 AWD 5MT
- Title Whore
BC672 = 2.2L N/A Sedan.
Kelley - Aegean Blue Metallic. Looks blue sometimes, green others, and in the right light, it looks kind of purple. It's sweet, like a precursor to WRB.
MK - What springs do you have? Whiteline? That's the exact stance I want.
http://www.main.experiencetherave.com:8 ... decode.jpg
BAC: they are GAB revolution II coilovers, a full setup. some of the other brands would probably get nearly the same results (whiteline, tein, etc..)
MK
MK
1992 BC672 AWD 5MT
