Curious if the backing plates on the rear hubs can be taken off easily?
I'd sort of prefer to use the ones on my car rather then the donor. Plus I accidently banged on one of the studs, and the tip of the threads is a little marred. I'd like to knock out of the studs on mine to use it.
Is swapping the backing plates and or changing studs something I'll need a press for, or do I just have to take apart the parking brake stuff?
Hubs & backing plates
eastbaysubaru
You'll just have to take apart the parking brake stuff. I talked about the same things when I had a stripped wheel stud. I even think there's a thread about it. Basically you've got to take it all apart so you can move the ABS (tone?) ring far enough away so you can smack the stud out.
-Brian
-Brian
'04 PSM FXT
Thanks brian,
I'll see if I can find your thread.
So it can be done without pressing the hub out? That's my main concern. Guess I'll be doing that this week.
