Need a quick part #
Need a quick part #
Any one know the part # for the oil supply line, for the turbo? The all metal one that comes in the top? Mines leaking onto my brand new turbo.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
TDGKORN's got the right number.
Unless you marred one of the sealing surfaces of the banjo, though, I don't see how the line would fail. Did you use two new 10mm annealed copper washers, getting both old ones off first?
Thanks guys!
I looked again and I think I'm missing the lower washer!
I'll get one on there asap. I think it was missing before because with my old turbo it was leaking too. It's not leaking that bad now though thankfully.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Ooh, that's not good.
They do sometimes get stuck onto one sealing surface or the other, so look carefully. All the dirt turns them black so you can't always tell. If you have to use a screwdriver to pry them loose, be careful not to scratch the mating surface, of course.
Did you use a new washer for the upper one? Most auto parts stores should be able to give you a 10mm copper washer. They're the same ones as for our brake calipers. If you can't seem to find one, let me know; I think I might have some in my car's glove box.
