Will 205/55/16 fit a '91 Legacy Wagon LSi ?
I recently found a good deal on a set of snow tires from a WRX owner. I now own a set of OEM steelies with 205/55/16 rubber. Just putting them up against the Legacy they appear taller than the 195/65/15's already on there. Can anyone tell me if these will fit or not ?
Mostly. You're right; they're a tiny bit taller.
There are many of us on the board running 205/55-16 tires, myself included. You may experience rubbing on the hardest of corners with the heaviest of loads, but in general it should be okay.
They shouldn't rub at all, unless under the conditions that Vikash mentioned.
WRX's never had OEM steelies though, did you get WRX alloy's?
Are all LSi's AWD? They may not fit if they aren't.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
umm..... is this where i'm supposed to chime in?THAWA wrote:Are all LSi's AWD? They may not fit if they aren't.
I just got some new Kuhmo ASX 205/55/R16 which are the same "size" as the old RE92's which did fit fine on my FWD. The Kuhmo's seem a little wider than the potenzas though, so i'm having issues with rubbing on the spring perch again. (hopefully I will have those taken care of by the end of today.)
It all depends on who makes the 205/55R16 in question.
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
What isnt a performance car? Are you sure you know where you are?Legacy Wagon wrote:Its not exac tly a "performance" car so I won't be doing many hard corners.
This was taken when I first bought the car back in 2001. You can slide underneath to change the oil without raising the car.
Of course, what's a Subaru if you can't get it dirty. This was "by accident" , I got lost in heavy rain going through a development in contruction and ended up on a muddy flat where only CATS with full tracks were moving. Spent 30 mins in the wash bay spraying off all the mud.
And as much as its not a "performance" car I have done well competing with it. I did a seaon of Solo II type competition in the winter and beat out WRX's & Audi Quatrros
Here's a pic from an Audi rallye I joined. They laughed at my car until the roads got really rough. Then, I was the only one not bottoming out at full speed. Maybe its the corner but the suspension is really hunkering down in this shot. A far cry from the 4x4 look when its parked
that's sweet, I wonder what was put in it? I'd love to have taht kind of ride height
Am I seeing things or do you have velour interior? I thought all LSi's had Leather?
