95 Legacy Air Conditioning
On my 95 Legacy Outback the A/C clutch cycles on & off as I drive or sit & idle. The air is cold but I have never seen a compressor cycle unless there was a problem. I have a little froth in the sight glass. Any suggestions? Is this normal? Thanks.
Pat Callaghan
94 Legacy Ti Wagon
94 Legacy Ti Wagon
A little froth in the sight glass of an R-134a system is to be expected even with a correct charge; that's why a lot of R-134a systems don't even have a sight glass.
I don't know for sure about your 95 Outback in particular, but I think it's supposed to cycle on and off. It's part of the system that maintains an appopriate refrigerant pressure/temperature in the evaporator core. If you watch most cars idle with the A/C on you'll see the compressor cycle on and off.
Excessive cycling can be caused by an incorrect charge of refrigerant, so if you think it's cycling too often you could evacuate and recharge the system with the correct amount of refrigerant to be sure.
Aaaah!
The gauges on those Interdynamics-type kits are next to useless. The packaging and advertising are very misleading about this.
But even a quality set of manifold gauges can't tell you if the system is properly charged.
The best way to make sure the system has the correct refrigerant charge is to evacuate it and then put in the correct charge (for your car I think it's somewhere around 24 ounces, which is usually around 2 cans).
I would really recommend doing that based on what you've said in this thread.
