Hi. I have a 90 Legacy LS FWD with an automatic transmission. I’ve been having very intermittent problems starting the car over the last 6 months– turn the key and nothing happens. If I shift between Park and Neutral I can usually get it to start right up, so I’m making an assumption the Neutral Safety Switch is out of adjustment/bad.
Does anyone know where the switch is located? Also, any ideas how to check if it is out of adjustment, bad? Again, I’m not sure the switch is bad, but from the symptoms it’s the first place I think I should look.
Thanks –Joe.
Neutral Safety Switch Problem?
Joe
Ex-'90 Legacy LS
Ex-'90 Legacy LS
I have this picture:
http://www.graphics.cornell.edu/~v/pics/nss.gif
Apparently, to properly adjust the neutral safety switch, you loosen the bolts around the switch, then shift to neutral, then stick a pin through holes that line up in the shift lever and the switch, then tighten it all down.
I wish I could offer more knowledge, but that's all I have. Maybe that picture makes sense to you? It looks like the switch is where the shift linkage meets the transmission body.
