Starter or safety switch? Or....?
Bosco
Post by Bosco »
The 92 SS has been acting up as of late...
It starts fine often enough, but lately has been getting in to a habbit of just clicking once, and not starting. Sometimes the starter drags slowly through a turn or 2 then stops. I believe just turning the key back and forth again usually starts it.
I have not been driving that car at all lately, and have never experienced it myself, I think it sounds like the starter, but I figured I'd ask here before getting in to it.
Thanks in advance for any comments.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
professor
Post by professor »
check your battery connections, and your starter connections and ground straps for tightness and cleanliness. In fact just take them off, clean 'em up, and reinstall. if your problem persists, there is probably a dead spot on the starter motor winding. Sometimes they can soldier on a long time like that, sometimes, not.
I'd take less chances with an automatic, no jump starts available
might be the starter solenoid contacts. It's a fairly common problem, especially in the AT's
Bosco
Post by Bosco »
Thanks guys, I'll look in to all that.
93Leg-c
Post by 93Leg-c »
A new battery and a used starter solved my starting woes. I had your same symptoms at first and it just got worse until the replacement parts were installed.
93Leg-c
Post by 93Leg-c »
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 02901&rd=1
This remanufactured starter would fit your car.
