SOHC TO DOHC ????
91legacyman
SOHC TO DOHC ????
Post by 91legacyman »
im looking to upgrade my 91 legacy L to dohc i need to know if its possible with the 2.2 engine i got in there now or do i have to do a complete engine swap? thx :D
THAWA
Post by THAWA »
yes its possible
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
BAC5.2
Post by BAC5.2 »
If you have the time, money, patience, and money, it's possible.
The question is whether or not a 91 Legacy L FWD with a plain-jane EJ22 would be worth dumping almost 8 grand on to convert.
What are your goals with the engine. You say you wanted a turbo setup, and now DOHC. If you are questing for high hp, you didn't pick the best engine platform.
91legacyman
well i was just wanting some knoledge on it and i dought i would have to pay 8 grand for dohc heads i can prolly get them for real cheap and take them to napa to get a acid bath tested and even port and polished probly but yea if its possible i do have the patience and money i love my subaru i wanna juice her up cuz out of all the subarus ive owned mostly xt6's but nice i never juiced them up
91legacyman
oh what would be a good head to use ?
BAC5.2
Post by BAC5.2 »
There isn't a DOHC EJ22 that I've ever seen (well, except for the 22B, but you'd NEVER find those heads), so you'd have to adapt EJ25 heads. Then you'd have to run standalone engine management, since the stock ECU has NO idea what's going on since it's only programmed to know what's going on with one cam.
It would be MUCH easier and cheaper to swap an EJ22T into the car than to deal with the pain of doing a DOHC swap.
$8k isn't for the heads. It's for everything you need to get the heads to work. Morgie spent just over 6k to convert his EJ22T to a DOHC motor, and he got a DEAL on everything.
If you really want to to do it, you definately could. I think it's a bigger project than you are expecting, and on an N/A EJ22, you've gotta ask if it's REALLY worth it (in terms of block durability).
Post by entirelyturbo »
BAC5.2 wrote:so you'd have to adapt EJ25 heads.
Or EJ20 DOHC heads, which morgie did.
*Formerly DerFahrer*
91legacyman
well i deffinitly know its not a walk in the park (not trying to be a smart ass) just looking to invest into my baby and take my time but from what u guys r tellin me i would think it would be best to buy a hole other engine tear it down and rebuild up like i want and just keep my engine i got in there now on the back burner cuz there is nothing wrong with the engine now its clean as hell and i try to keep it up plus i like to do all the work to it myself cuz down south some ppl dont really have a clue about subarus inless there acually certified so ok we nixxed that idea so is there a engine that allredy has DOHC that would fit into my bay? :roll:
greg donovan
Post by greg donovan »
a jdm DOHC N/A EJ20
a phase I DOHC USDM EJ25
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
91legacyman
thx greg ill study those whats the phase I DOHC usdm ej25 whats the difference between the two ? is the ej25 turbo and ej20 n/a or what?
phase II ej25s are SOHC. I'm not sure what your second question is, but there are N/A versions of both EJ20s and 25s as well as turbos, though only the new cars have factory 2.5 turbos.
91legacyman
i just found a ej20DETT TWIN TURBO JDM the thing is sayin it fits a b5 chassis but could i make it fit a b10 ?
THAWA
Post by THAWA »
no you didnt, and no you cant
for the first part there's no such thing as an EJ20DETT I assume you've looked on ebay and found an auction that says that. That's just the seller not knowing that DETT isn't a naming scheme for all engines.
second part the second turbo runs right into your brake master cyl, it's setup for rhd cars so ti'd work i that situation. This raises a question i've been wondering, where is "savannah"
GA ... suspicious, Hardy?
THAWA
Post by THAWA »
curious
greg donovan
91legacyman wrote:thx greg ill study those whats the phase I DOHC usdm ej25 whats the difference between the two ? is the ej25 turbo and ej20 n/a or what?
the jdm N/A EJ20 is a DOHC non turbo 2.0 liter motor.
the USDM phase I EJ25 is a 2.5 liter DOHC non turbo found in older legacy gts and outbacks and the older RS. this motor is not as strong as the phase II N/A SOHC ej25 found in the newer cars. the phase I had problems w/piston slap and the headgasket. the phase II is a better 2.5 liter in my opinion. output is around 165 HP and torque. both peak around 4,000rpm.
for some reason a N/A SOHC subaru motor makes a little more power than the DOHC ones. less parsitic loss or something like that thanks to a less complex valvetrain.
96 Impreza L sedan
00 Impreza RS sedan
BAC5.2
Post by BAC5.2 »
Steve already answered it.
BAC5.2
Post by BAC5.2 »
THAWA wrote:no you didnt, and no you cant
Indeed. "DE" is a Nissan term. SR20DET, RB26DETT, etc. DE denotes DOHC.
The EJ20TT is a DOHC motor, but I wouldn't buy from a seller who doesn't know how to properly code the engine he is selling. Espically if he's an actual importer and not just some guy trying to sell his engine.
I HAVE heard that the EJ20TT heads flow differently than the EJ20T heads. But that was on the internet, so take it for what it's worth.
And please, can you at least TRY to use proper grammar in your posts? At least just use SOME punctuation.
THAWA
Post by THAWA »
BAC5.2 wrote:Espically if he's an actual importer and not just some guy trying to sell his engine.
BAC5.2 wrote:And please, can you at least TRY to use proper grammar in your posts? At least just use SOME punctuation.
sorry, I couldnt resist :)
Matt Monson
Post by Matt Monson »
Only one comment to add to this tread. If you put EJ25 DOHC (or EJ25 SOHC or EJ20 DOHC) heads onto an EJ22 NA engine you will habe a CR in the mid 8's. This would work if you were gonna do a moderately boosted turbo set up, but wouldn't be worth a damn on an NA car. As has been suggested, swapping in a complete NA engine is a better route for a non-boosted engine swap...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
scottzg
Post by scottzg »
i once emailed that georgia ej20dett guy and said id never heard of that engine code and perhaps he was mistaken. He had the most amazingly insulting response, something about idiot kids telling a professional importer about engine nomenclature. I wish i still had our correspondences. In short, that guy is an asshat and i wouldnt want to talk to him again, let alone do business.
91legacyman
um yes i did there is one on ebay its got 3 days left and u know what its not to far from where i live heh
91legacyman
so that engine isnt really a subaru engine ? if its not disregard that last post ,could it be a scam?
BAC5.2
Post by BAC5.2 »
Good catch Hardy! My bad, lol.
The EJ20DETT thing is an EJ20TT with improper nomenclature. I would stay away from it though, as someone who's worth a spit that would be in posession of that engine, would sure as hell know it's code.
There are a LOT of easier ways of getting power.
91legacyman
i think im gonna buy a EJ25 DOHC used and just install a turbo on my EJ22 if i like the EJ22 with the turbo ill just stay with that and build the EJ25 on the side and install a turbo on that bad boy
