i have a set of toyota camry 5x100 14" steel wheels and a set of 14" blizzak snow tires that i was planning to run this winter. however, upon measuring the backspacing, OEM subaru is ~130mm (5 1/8"), and the camry's are ~115mm (4.5").
so, i'm going to guess that makes the camry's offset ~40mm. is this "ok" for my snow treads? they're 195/60-14 blizzaks and i believe the wheels are 14x6"
low offset 14" wheels with snow treads for winter?
1990 Legacy L Wagon AWD Auto - hers
1994 Legacy L Wagon AWD 5spd - his
BAC5.2
Test fit them. If they fit, great. If not, then go to a junk yard and canibalize 4 steel wheels from a Subaru. Sounds like a really low offset to me, but whatever.
yeah you will if you leave those wheels on. I'd say get them mounted on your current wheels
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
