GD Shifter Bushing...
BAC5.2
Post by BAC5.2 »
Got an Energy Suspension bushing for a GD the other day for my birthday.
I wanted to see if it would work.
Popped out the stock bushing last night. Compared it to the GD bushing.
The flanges on the new GD bushing were significantly larger than stock.
Didn't have time to put the stock one in last night.
So today, I decided that the easiest way to see about swapping the bushing was to drop the whole shift linkage and look at it with more room.
I tell you what, the bolts for the shift linkage are a BITCH to get to with the driveshaft in place. I did get it, however, from above.
Used a pair of snap-ring pliers to pull the snap ring holding the shift lever in place. Pulled the whole main linkage assembly and dropped it from the car.
There was no way the Energy bushing was going to fit with the flange at the same diameter.
I pulled out my trusty Benchmade and carved the edge down a bit. Took off about 1mm all the way around.
I then went to the basement, and made a Press using a C-Clamp and a peice of Polycarbonate that seems to be a more useful tool than a Screwdriver.
Clamped it down and got it seated. It popped in. I was right, though, that the diameter of the center of the bushing was slightly larger for the GD than for the BC. It went in OK with some lithium grease and fit well.
Got back out to the car, slipped it on the spindle, bolted the bracket to the body again, installed the shift lever (first test fitting the stock WRX shift lever, but that was a negatory as the ball on the end of the shifter was to small in diameter).
When I went to bolt it down on the spindle, something interesting had happened. It wasn't seated properly.
I went to the garage and grabbed a washer. Slipped the washer on the bit of exposed bolt and started wrenching. That pressed the bushing and linkage all the way down and set it perfectly :)
Reinstalled the stock plate and the spring (not sure what it does, but hell, it came off it's goin back on).
Got everything back together and bolted up.
It's surprising what a difference it makes. In the driveway, I didn't notice anything, but once I got out on the road, it was awesome.
Most of the slop (what little slop I had) was gone. It's a solid feel but still really smooth.
Subaru shifters have a rap for being "vauge and rubbery" almost like Volkswagen shifters. I can safely say that this is no longer the case for me.
The only play I still have is on the rear bushing for the shifter. The bracket has a built in bushing, and mine is about as rubbery as the stock motormounts, it's actually breaking apart and cracking.
Once I figure out a stiffer option for that part, I'll be golden.
I also noticed a lot less grinding, which I attribute to the HORRIBLY flexy stock bushing.
I highly recomend this to EVERYONE. It's like steering rack bushings, there's no negative effects unless you like sloppy shifters.
I think my dad got it for 11 bucks on e-bay. Search for "WRX Shifter" and you should see a ton of them. Part number was 1170.
I've never driven a Subaru with a shift as bad as a VW. I like mine more than the new Maximas I've driven - shorter throw, more accurate. It's not the best shift in the world, but I think the big complainers are coming from Hondas, which are pretty nice.
Still it never hurts to improve things.
BAC5.2
Post by BAC5.2 »
I've driven a lot of cars. My stock shifter felt like my buddies new VW Beetle.
Reguardless, it is much better now :). There's no excuse not to do this, unless you don't know what your doing.
I could do it again, probably in about 20 to 30 minutes.
I still think subaru's shifting is below par!!
I may be biased or too nit picky, but oh well.
I will find the ultimate combo for reduced throw, without notchiness. The stock WRX linkage, kartboy bushings & shifter look to be the next setup to test. Once I get that setup perfected, I'm going to tackle that damn joint that connects onto the transmission rod. It's introducing 1/4" of play at the top of the shifter, and it's the piece that is "riveted" that is causing the slop. I'd like to drill it out, and replace it with a nylon bushing of some sorts.
BAC5.2
Post by BAC5.2 »
Wow, you have 1/4" of play at the top of the shifter!? I don't even have that much play.
Is the Turbo shift linkage different than the N/A shift linkage?
I'm just going to die some more threads onto my stock shifter to get the knob to sit lower (compare the stock shifter to the WRX stock lever, and the WRX lever has almost 3/4" more threads). That should smooth things over a bit and get it to where I wan't it.
The thing is the older linkage is completely different then the new ones. Doesn't matter whether it's turbo or n/a. Just age.
The joint piece is metal with bolts and such. The new one has this rubber/neoprene bushing. One joint is riveted, the other connects to the shifter linkage. The one that is riveted is where the slop is coming from.
http://www.surrealmirage.com/subaru/ima ... joint1.jpg
http://www.surrealmirage.com/subaru/ima ... joint2.jpg
http://www.surrealmirage.com/subaru/ima ... joint3.jpg
You can see what I mean in these pics. I want to drill out that rivot, and put nylon bushings in there. That will give me 0 slop :evil:
So once I get the shifter issue taken care of, I'll work on that joint.
legacy92ej22t
Post by legacy92ej22t »
BAC5.2 wrote: I could do it again, probably in about 20 to 30 minutes.
Hmmm, really? *scratches chin and laughs*
That's dope Phil! I should do this. If/when I get a new motor I'm defintely doing my motor and tranny mounts. Hopefully I can do my clutch too. But, as you know, I really need to do my shifter bushings too.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
BAC5.2
Post by BAC5.2 »
Matt - 12 bucks for the bushing (ebay search: WRX Shifter) and get the Energy bushing. The only other tool you need is a 4" C-clamp, some patience, a snap ring plier, and a 12mm socket and 12mm box-wrench. Oh, and a knife to shave the bevel off of the new bushing.
Ask Vikash, my shifter is as tight as a... nah, I'll spare the vulgar joke.
Driving it tonight, I couldn't be happier with how it went.
1/4" play? As bad as a Beetle? Jesus, everybody elses stuff seems to wear out much faster than mine. I must drive like an old lady. I do have an occasional sticking from something feeling like it's jamming slightly in the linkage, but not too loose.
Grandma Solberg
BAC5.2
Post by BAC5.2 »
Josh - I didn't pay attention to the stock unit, but why is that peice better than the stock peice to adapt the WRX shifter? Like why won't the stock peice work?
BAC5.2 wrote:Josh - I didn't pay attention to the stock unit, but why is that peice better than the stock peice to adapt the WRX shifter? Like why won't the stock peice work?
To be quite honest.....I don't know. I was told by Richard Buckner and Dave that in order to use the sti ss, I would need that adapter.
The old style linkage has something similar to it, but I don't see how it can be too different, unless the axis of how the shifter hooks up is 90 degrees different ie horizontal instead of vertical.
I don't have the old tranny around any more to look either.
