There's a LSD from an '88 Subaru RX at a local junkyard here. Anyone know if this would swap into my '93 Turbo?
Also, I know next to nothing about suspension/handling/drivetrain. What benifits could I see from this?
-mike
LSD from '88 RX?
Sir Yach-o
LSD from '88 RX?
I'm saving up for my Yugo.
The RX should be a 3.7, you need 3.9. Unless you wanted to dig into the diff and change some stuff, keep looking.
LSDs actually tend to give a car more understeer, but a larger rear bar can balance that out. The traction benefits in all situations are greatly improved.
Legacy Central
Sir Yach-o
- quasi-mod-o
All FWD legacies had 3.70 final gear reduction
All Turbo legacies had 3.90 final gear reduction
All MT AWD legacies had 4.111 final gear reduction
Some AT AWD legacies had 4.111 final gear reduction, and some had 3.90 final gear reduction.
and I'm speaking of the 1990-1994 MY's only
What he said.
Legacy Central
