Droplinks to Endlinks WRX
tris91ricer
- Title Whore
OK, so i bought some 02wrx rear endlinks, but since I've got droplinks on the 92 legacy, I can't use these yet.. I want to kinda beef up the rear end a bit, and then hunt down some stuff for the front.. but meanwhile, how can i convert from droplinks to endlinks?
anyone have any ideas?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
get a set of lateral links from any newer MY legacy....
tris91ricer
- Title Whore
tris91ricer
- Title Whore
These are lateral links
http://www.surrealmirage.com/subaru/ima ... P_3152.JPG
http://www.surrealmirage.com/subaru/ima ... P_3195.JPG
You can use WRX wagon lateral links only. The sedans have a wider stance.
You can't use the lateral links you have because the current style endlinks won't fit in them.
http://www.surrealmirage.com/subaru/ima ... P_3140.JPG
http://www.surrealmirage.com/subaru/ima ... P_3407.JPG
NuwanD
yep, basically any subaru (except wrx sedan and sti) after 1993 will have the correct lateral links to swap over to... I did this swap along with whiteline endlinks and it is the single biggest and best difference i've made to the cars handling, fresh bushings and the stiff endlinks are grrrrrrreat!
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
2004 Forester XT
Didn't they change the rear suspension setup for the 00-04 legacys though?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
yeah....pretty sure they are different.THAWA wrote:Didn't they change the rear suspension setup for the 00-04 legacys though?
so for a conservative list 93-01 imprezas & 02+ wagons can be used along with 93-99 legacies.
tris91ricer
- Title Whore
scottzg
never mind. I cant read.
If anyone knows why they went to the "c" shaped links, I'd like to hear it. If you look at the bottom of the car, the mounts on the lateral links are the lowest thing in the area which might hook something in a rally situation.
I suppose they just didn't have room to use a conventional dogbone-shaped link, or is it that the sway bars fall directly over top of the lateral link (due to the original centered droplink), forcing the use of something shaped strangely to stay out of the way of the moving lateral link.
I'm just surprised that something that seemed like a retrofit situation would carry on for years through many models, rather than being scrapped for shorter, simpler arrangements.
scottzg wrote:And a model.Legacy777 wrote:
93-01 imprezas.
I think it was partially due to fabrication costs. Instead of having that box type lateral link, they can just use a metal rod, which probably cost less. Plus I think the drop link style was not as rigid.professor wrote:If anyone knows why they went to the "c" shaped links, I'd like to hear it. If you look at the bottom of the car, the mounts on the lateral links are the lowest thing in the area which might hook something in a rally situation.
