totech
Post
by totech »
Here I am putting on a Winter Height suspension and all I can find in my pile of parts is two right front struts.
Apart from the obvious ABS and brake line connectors, can anyone see a reason why it would not work?
Both front springs are identical, so that is not an issue, both struts look identical, apart from the brake line and ABS connector - so...
Anyone got any ideas?
08 GE - SWP
96 BG - SGP
96 CX - EBP
scottzg
Post
by scottzg »
the upper spring perch will rub against the inner fender area. It will not work.
totech
Post
by totech »
How about I use the correct spring perch - just use the right strut, and left spring and other parts..
08 GE - SWP
96 BG - SGP
96 CX - EBP
scottzg
Post
by scottzg »
I don't know, i dont think so though.
totech
Post
by totech »
I'll let you know tomorrow...
and these are STI ver5 struts - I have 3 front right &^(P*)&*^$$#@@
08 GE - SWP
96 BG - SGP
96 CX - EBP
totech
Post
by totech »
Seems to work fine - drives fine too.....
Wonder if I can turn left now - since I have two right struts.....
08 GE - SWP
96 BG - SGP
96 CX - EBP
boostjunkie
Post
by boostjunkie »
Did you have any problems attaching the brake line on the strut that is on the wrong side?
totech
Post
by totech »
boostjunkie wrote:Did you have any problems attaching the brake line on the strut that is on the wrong side?
Nope, a lot of people use zip ties anyway, so I just used them to attach the line to the abs line bolt.
I then used the older bc's brackets to attach the abs parts.
08 GE - SWP
96 BG - SGP
96 CX - EBP
