Do you have hesitations? What type of intake do you have?
Snorkus, filters, throttle bodies and intake manifolds.
biggreen96
Post by biggreen96 »
Im thinking that my hesitations might not be ingnition related. I remember reading that cone filters may give the sensor a hard time.
Whats your intake and hesitation situation?
J-MoNeY
Post by J-MoNeY »
Mugged, K&N, De-Snorked.
No problems.
98 LGT
irishsetter
cooling block
Post by irishsetter »
where did you get that metal cooling block my plastic stock one bit the dust.
scottzg
Post by scottzg »
I had hesitation when i had a cone filter. Stuck a box on it, gone!
Subaru_Nation555
Post by Subaru_Nation555 »
Stock except for a K&N. I have slight hesitation problems, so days are worse then others, but not as bad as some people seem to be having.
'06 Impreza 2.5i wagon
azn2nr
Re: cooling block
Post by azn2nr »
irishsetter wrote:where did you get that metal cooling block my plastic stock one bit the dust.
thats dlc;s old car. he had it custom made.
i have a mug and a cone and it doesnt hesitate like it used to where it would litteraly jolt back and foruth. now it sticks to 3k rpm at full boost and keeps speeding up without reving higher, but it doesnt do it all the time. when it does decide it wants to go past 3k rpm i chirp the fronts
-jason
