Recall, I replaced my throttle body because I had messed with stopscrews in the past and had no way of returning them to their original position. So I have an untouched throttle body with all factory settings and a good TPS.
I've been noticing my idle dropping to about 500rpm lately, and since all of us have had weird idle from time to time, I pretty much ignored it...
Until today. I was heading toward a turn, so I put the clutch in and slowed down. I had a clear shot, so I began to turn, when I noticed I had no power steering. I looked at my dash and lo and behold, my dash lights are on and my tach is pointing at 0
I took the turn without PS and then turned the engine back over and continued on my way to work.
I really really don't understand why it's doing this. This is exactly the same thing it was doing when I first got it, except the fact that I have an IAC valve that is less than 2 years old, I have absolutely everything fresh in my car, the engine is in a perfect state of tune. I have not had a CEL come on in almost 2 years.
What have I got left to try?
