Retrieving ABS codes when there is no LED on unit
My 94 GT wagon has no LED on the ABS ECU
It's "ABS" light is on any time the engine is running.
What do I do to make the unit flash the "ABS" light
yielding the error code
Thanks in advance for any help
pict of ABS comp
Thanks for the reply and to answer your
questions
Yes I believe it is a North American model
It was built in Indiana but I have no way of
telling if it was built for the N.A. market.
As for the light on the unit.
I cut the carpet away looking for it
Then another member showed a pict of his and mine has no
LED. I do not believe it to be a replacement but anything is possible.
I thought there was a plug above the throttle
pedal with jumper leads taped to it.
Can't I plug a lead into the proper pin in the plug
and get the ABS light to flash the code?
questions
Hmm, so you have an automatic, with the 2E ABS system? I don't really know anything about 2E... the earlier systems all had the light on the control unit.
But according to this article: http://endwrench.com/images/pdfs/ABS.pdf
You are correct; you need to ground a pin on a diagnostic connector and then the idiot light will flash out the trouble codes. Unfortunately, the article doesn't give all the necessary details.
But it does say early Imprezas also used the 2E system. So maybe you could try using this information meant for 93 Imprezas:
http://www.graphics.cornell.edu/~v/pics/93gcabs.pdf
There seems to be a good deal of Legacy information mixed up in that Impreza article, but maybe you can make sense of it... The codes are probably all the same, so if you can locate the L terminal on your car based on the illustration there, you should be able to do it.
Let us know if it works!
May want to check this out.
http://www.main.experiencetherave.com:8 ... s_diag.pdf
You may need to jumper the connector under the dash together and read the blinking of the abs light.
links an such
Thanks for links guy's
I downloaded and read all of them.
Then went in search of the connector.
I found a black "U" shapped 6 pin and it
looked like the picture but there was no wire in the lower
right corner?
I also found a yellow nine pin that looked similar.
None of the connectors had leads taped to them.
Will have another look at the links today and count pins in the pictured
connectors.
Thanks for the replies.
right corner?
connectors.
Hmm, the figure of the Impreza connector looks more like a 3-pin connector than a 8-pin.
Wait a second! I have a copy of the 93 Factory Service Manual supplement! It should have a full treatment of the 2E ABS system. Let me look it up.
D'oh. It says 'Refer to the previously issued Supplement "ABS-2E" (Pub. No. G208BE)."
I have no idea what to do with that publication number.
And the wiring diagrams section doesn't even include a section on the ABS system.
But hey! This might help: Josh has a bulletin with corrections to that publication.
http://www.main.experiencetherave.com:8 ... ABS-2E.pdf
It looks like you're looking for a 2-pin connector underneath the fuse box area. Hopefully there's only one.
I do believe that the .pdf files in this thread link are what you need
http://forums.nasioc.com/forums/showthr ... did=192583
cornfused
Thanks for the links, looked at all of them
VRG I need to know what connector P58 looks like
Did you see a 2 pin connector in another picture?
The wiring diag, shows P12
Prof, thanks for the link, I went and looked at the .jpg files,
didn't see any .pdf files
It shows what looks like a six pin connector, I'll also look for it
I have been concentrating my search on the wrong side of the
st. col.
All other articles say the diag. connectors are ground wires.
If they are not present?
I don't know if I'm comfortable with sticking a ground wire in unknown
plugs
I wish one of the pictures would mention a color
I will assume black
Will look tomorrow and get back to you
Thanks again for all the time spent in this search
st. col.
plugs
I will assume black
The PDF I most recently linked to shows where to look for the 2-pin P58 connector, and it's specifically for the BC/BF Legacy, so I'm pretty sure that's what you want.
I don't know what to say if you're worried about sticking the ground wire in... I'd say first see if you can find the connector, and if it's the only one of its type you can feel pretty confident about it.
ah sorry
Sorry VRG3, I din't mean to dis you.
I downloaded the .pdf and blew the picture up as far as I could
but couldn't make out the shape or number of pins on the connector.
They only mention two pins so I guess there are only two.
Will look for it today and report what I find
blind asa
VRG3, I'm just blind, thanks I now see where the connector pict is.
Guess I was looking so hard at the forest I missed the trees.
So I yanked the panel and
WHOOP dar it was, white two pin connector
So I grounded the L terminal
Turn on the ig sw and
My ABS light starts flashing like a christmas tree.
I have read Subaru error codes before
Saw what I believe was the start code (11)
Then there was a series of error codes, so many flashes
it was very difficult to read all of them.
They appear to match some of the codes on the link
Leg 777 gave for the early Impreza's
(i.e. 21 ,29, 31)
I think I should clear the codes and try it a fresh.
Is the clear memory proceedure the same as the early Impreza?
Does Josh have the rest of the 92/93 ABS service manual on line?
Thanks for staying with this old blind bat,
we are getting somewhere
thanks to your help
(i.e. 21 ,29, 31)
thanks to your help
Yeah, early automatic Imprezas have basically the same ABS system as your car, so the codes should match up.
It couldn't hurt to clear the codes and see which ones return. That's usually the way to go with engine trouble codes.
But one notes that code 21 is for the RF sensor, and code 29 is for the tone wheel (I'm not sure what that means -- maybe it's saying the previous code is for the tone wheel rather than the sensor itself?), and code 31 is for the RF valve.
It seems odd that the valve and sensor would both be bad for the same corner... it's possible that the computer quit controlling the valve when it noticed the sensor problem.
With engine trouble codes, the proper procedure is to always fix the first code that comes up and then clear the codes before progressing to any others. Maybe that applies here too. So maybe you need to inspect your right front hub.
I'd make note of all the codes, clear them, and see what comes up again.
I don't think any of us has access to the complete ABS 2E supplement...
I would say the 3 quick groundings is the right way to go. The End Wrench article says to do that too, and it's not specific to any particular model or year. Apparently you'll know you have it right because you can hear the relays in the hydraulic unit click when the codes clear.
NO DICE
Well I gave it a shot
three quick grounding of the L terminal ---> nada
tried the other terminal --- > same
grounded both and hit the brake pedal --- > you guessed it - nothing
So I will recheck the tone rings and give a look at
all the sensors.
Wonder what kind of resistance value they have.
Sould check all at the ABS ECU and compare.
I have already electricly tested both relays in the ABS unit
The fuse in the under bonnet box is good.
I would like to have this fixed before the snow falls -read any time now.
all the sensors.
so I've got a 94 L wagon with the ABS-2E system. The light came on so I grounded the L connector and read the codes. Now I want to clear them, but grounding the L connector 3 time in 12 seconds with the key in the run position doesn't do anything! I tried pulling the battery cables for a good hour, but that didn't clear the codes either. Does anyone know the right way to clear the codes out of this ABS system?
If the code won't go away, there's a possibility the problem still exists.
okay so I figured it out. You have to ground the L connector and then turn the car ignition to run. Then you disconnect and reconnect the L connector 3X to reset the codes. When I did it this way the codes cleared.
When I couldn't figure out how to clear the codes, I was turning the ignition to the on position before grounding the L connector. Doh.
After clearing the codes I drove the car and only one of the codes came back #28. Bingo... after some more diagnostics I believe I need to replace my left rear abs sensor.
