alarm
jpoyann
alarm
Post by jpoyann »
Hello,
I want to conect a kind of alarm I´ve got. It puts on and off a switch with 10 seconds interval to simulate an engine problem. The car stops and then the thieve is able to start it again and it stops again. However I don´t know wich fuse to use from the box near the driver.
Can anyone help me?
Thanks,
jose
Subaru Legacy 2.0 Turbo 4WD Sedan
tris91ricer
Title Whore
Post by tris91ricer »
so... your alarm makes the engine 'lope', and quit, but then the theif is able to start it again? What kind of alarm is it? Do the directions include some form of a starter disable, or some kind of interlock? You might want to have the switch(of which you speak?) running a switched ground to the starter, so that when it does attempt to shut the car off, it shuts it off for good.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
tris91ricer
Title Whore
oh, in regards to the fuse, use the one marked 'egn ign' or something to that degree.. it stands for Engine Ignition, i believe.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
What are you trying to select a fuse for? Are you choosing a fuse to tap to power the alarm, or are you choosing a fuse for the alarm to disconnect?
tris91ricer
Title Whore
oh, thanks V, i didn't think of that. I''m guessing (due to bad english) that he's installing something like a clifford with a starter-disable or something. I really don't know much about alarms, to be frank, but i would assume that tapping into the egn-ign fuse would get the results he's asking for...
thoughts?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
I can't have any useful thoughts without more information...
magicmike
Post by magicmike »
What he is trying to connect seems like a clifford type alarm with a carjacking feature. This is an extreamly complex alarm system. I DO NOT RECCOMEND YOU TRY TO INSTALL ONE OF THESE! but if you dare, what you are looking for is the ignition wire found in the steering column. the alarm system will have 2 wires. it works just like a starter dissable only it is on the ignition wire. It will be hard to install any clifford alram because they dont come with directions. They are meant to be proffesionally installed only.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
I actually did find the install diagram for my alarm on their site.....however I think they've since taken them down.
And yeah they are rather complicated. Messing with the ignition lead might not be the best thing. A starter interupt is a better way to go IMO.
tris91ricer
Title Whore
Okay, so now that we've all posted and given info on it, has our asker actually returned to get the info?? This is nice to know, though.. Was i on the right track then, for thinking of the engine ignition fuse?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
magicmike
Post by magicmike »
you were on the right track just going in the wrong direction ;)
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
tris91ricer
Title Whore
hey! alright! Thanks Magic Mike! I really appreciate your experience on this stuff, though.. I don't think i know many subaru guys that have electronics install experience that you seem to have, which, in our cases, seems to be very useful! Is it you that also makes custom boxes, too?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
magicmike
Post by magicmike »
Well I used to make custom boxes back in the day. I did custom fiberglass speaker boxes and speaker pods for doors and kicks. I am retired now from that stuff but I still know how to do it of course. I finally got a real job working for a machine company as a service tech wih some R&D and process development thrown in there also. I like it alot. But yeah, Alarms and remote starters are not that complicated in general but like anything you need to know how to do it. Some things require more than just plain instruction.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
tris91ricer
Title Whore
hmm.. I'll have to PM you with an idea of mine regarding a very expensive European alarm system...
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
