Legacy "Rally" Suspension
subarurx
hey all,
new to this forum, but I thought I would ask the question, has anyone got any of the suspension setting details from the Prodrive legacy that were use on gravel events, especially New Zealand. Specifically what I am after is:
- wheel alignment detials
- valving of the struts
- spring rates
I have just purchased a new legacy rally car (see it at my signature below) and it has crap Koni suspension. Use do to have DMS 50MM, but it was taken out, and I think it is a little overpriced.
Any help would be great.
thanks
Simon
- spring rates
thanks
Simon
REDHILLS RALLYESPORT
http://www.redhillsbenz.co.nz
greg donovan
BAC5.2
Type-R Yellow? Not my bag on the Legacy, but DAMN does it look pimpin on a GC.
Stiffer is better for gravel, apparently. Some research and backyard testing between my car and my friend's Impreza proved this to be pretty accurate. His superstiffly sprung Impreza glided and wen't wherever the throttle took him. My Legacy (we have identical alignment settings actually), with it's relatively soft suspension, would understeer and feel vauge. The weight had something to do with it, but it just didn't feel "right".
I want to know the setting of the Tarmac cars.
greg donovan
you also could try this page:
www.specialstage.com
go to the forums and then hang out in the car construction conference.
and that was a color subaru offered on the SS it is a very rare color. called electric yellow. it is the color that steve gingras chose to paint his '02 PRORALLY open class WRX
conventional wisdom for gravel set up is to have it softer than a tarmac setup w/lots of travel. of course this is stiffer than a stock roadcar setup.
check out TEINs GTECH coilover setup.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
subarurx
thanks all for your comments, it is a great colour, needs a bit of T&C and some sponsor decals on it, but it sures goes fast. The engine is brand new, and we have it running approx 310BHP at the moment running 20psi, witha link computer. we run anit-lag, and the gearbox runs a prodrive steel gear kit. Sadly I blew 2nd on my last event. When I bought it, it was minus the DMS suspension, which was a real shame, as that is what it needs t be able to be driven right. Have been looking at the Tein suspensoin, but no-one over here has used it for rallying, so I am trying to find something out about the HA's I think I have been recommended.
thanks
simon
thanks
simon
BAC5.2
JasonGrahn
Sure, having a stiff suspension is better, but there are other things that are coming into play there. How many times do I have to tell you this phil? Impreza = shorter wheel base = quicker turning.His superstiffly sprung Impreza glided and wen't wherever the throttle took him. My Legacy (we have identical alignment settings actually), with it's relatively soft suspension, would understeer and feel vauge. The weight had something to do with it, but it just didn't feel "right".
-Jason Grahn
Prodrive didn't do in house suspension development until the 1997 season so you won't have much luck on finding out what they ran on the Legacy. There is a guy in ME at Colorado State that has an Impreza and is putting both the Tein and DMS on a shock dyno to figure out what is better. I decided upon the DMS based upon the fact that that is their main focus, and where they started from. Tein's more into the tarmac side. Just think about it this way, Once you spend that extra $1200, 2 months later you won't even remember doing it. All you remember is how much it sucked taking the jumps/rough stuff carefully because you were worried about DNF'g due to crap suspension. Here's a link to the basis of my statement regarding development in the 97 season.
http://www.rallysportmag.com/cms/A_20298/article.html
Pretty good article all around.
Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
Denver, CO
Grant Hughes
Denver, CO
Denver, CO
Actually, I was talking to a Prodrive guy at rim and he said they still sold the old Legacy WRC setup. He told me to E-mail him if I wanted to know more about it, so I guess I will. For all I know he was talking out of his ass, though. I'll let you know what he says when he gets back to me.
peter@functionauto.com
tris91ricer
- Title Whore
I'd like to know a setup detaill about your rally car, if you don't mind... ?
Your mod list says 'polished intake manifold', and "ported and flowed' heads. Does that mean you had your intake manifold extrude honed, and your heads ported and polished?
If so, what do you think of the gains? Worth it? Negligible?
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
subarurx
they were all done before I bought the car from a friend who built it so I can't really comment.
the entire package works really well, when it got re-built last year and got tuned on the dyno, we had 315hp at the wheels, running 20psi. the power delivery is a bit slack below 3500rpm, but once the it gets over 4000rpm, the anti-lag arms and you are off, with the close ratio box, seems like you are constantly changing gears.
happy to try and answer any other q's, but I don't look after the mechanicals...leave that to the expert.
