Pulled the extra motor from the spare wagon but i can't get the torque converter off. Is it supposed to just slide off or what?
How do I remove the Torque converter from engine?
douglas vincent
posted a response to your thread on nabisco. You need to remove the bolts that hold the torque converter onto the flex plate. You can access these bolts through the little access plug hole on the engine bell housing....not exactly fun, but that's the only way to get at them.
