Automatic Seat Belts
nsantos23
Post by nsantos23 »
Hey Guys,
What does activate the seat belt when you close the door, what does make it to start running, is there a sensor or something? Mine is a little retarted, sometimes when i close the door it wont run back on the track so i gotta open the door and close it a few times to activate it.
Neo
1990 L 2wd 5spd 215K miles
tris91ricer
Title Whore
Post by tris91ricer »
Our resident genius, vrg3 can help you with diagnosing the electrical parts of it, however, I know that sometimes the belts just wear out. The solenoid that controls the seatbelts is in the vertical pillar directly to the sides of the front seats --it's covered by the plastic trim. Pull that trim off, and down near the bottom, you will see the seatbelt actuator. If you're willing to be risky, head out to your nearest junkyard and pull yourself another solenoid, to replace your failing one. This should make the belts work better, although, there's a reason we don't still have them today :wink:
Good luck!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
scottzg
Post by scottzg »
91legacy_sleeper wrote: there's a reason we don't still have them today
yea, cars have airbags now. One or the other is required on all vehicles
nsantos23
Post by nsantos23 »
Scott
Both are required on all vehicles, hahahahah
so what does make the seat belt roll when you close the door?????? is there a "bang"switch?
Neo
Neo,
The seat belts are activated by a switch in the door latch itself.
Your problem could be in that particular switch, or possibly in one of the limit switches.
Has the seat belt light guy on the dash blinked or stayed on? It's possible the auto seat belt computer has a code stored.
tris91ricer
Title Whore
Josh- There's a computer for the seatbelts? Damn, I should get some of this stuff fixed while I have the car sitting!
Got a link/doc/pic for it on your site?
THX!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
nsantos23
Post by nsantos23 »
Thanks Josh i'll check that, THX the computer on the sedan is in the left side inside the trunk by the hinge, remove the carpeted trim and there it is, usually the computer box is green.
again thanks josh
Neo
tris91ricer
Title Whore
no shit.. thanks josh!
Looks Like I've got my afternoon cut out, then!
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
