Alright, everybody. Today my dad and I ripped up more of my car, like the driver's side door panel and entire back seat assembly. This didn't come without its pitfalls, though...
There's a lost screw somewhere... the carpeting on the shelf behind the back seat is totally ruined, the "vents" on the shelf have snapped in half, one of the holding clips on a quarter panel shattered, one of the pieces that the holding clips hang on is missing... so essentially, there's a lot of issues due to the age of the car and the fact that none of these parts were altered since 1989.
My first question is for any of you who have attempted to remove the rear shelf and had parts of it ruin themselves, like mine did. Would you simply fabricate a new shelf and new carpeting, or is there a place to buy a replacement?
I'm pretty sure that we'll find the lost screw and hanger-thing... but just in case, does anybody know a place to find such insignificant replacement parts?
The next question is for any of you that have installed aftermarket amplifiers in original model year Legacy sedans. I'm thinking of mounting mine in the trunk, possibly on the red crossmember behind the rear seat. So, what's your advice on where and how to mount the amplifier? For reference, it's too large to be mounted where the stereo used to be, and too large to be mounted under either seat.
That's it for my questions. If you need to know anything more to be able to answer me, then I'll answer as quickly as I can.
Thanks a lot!
Calling Out For Opinions!
Nomake Wan
[url=http://www.cardomain.com/ride/762395]1990 Legacy L (Sold)[/url]
[url=http://www.cardomain.com/ride/2564067]1992 SVX LS-L[/url]
[quote="LaureltheQueen"]I like my automatic, it's fun to drink coffee and smoke civics at the same time[/quote]
You could get replacement parts from Gary's U-Pull-It in Binghamton or from Horseheads Pick-a-Part. Both yards usually have at least a few 1st-generation Legacies, and they probably wouldn't even charge you for just a clip and a screw. Or you might find a sedan whose entire hat shelf assembly you could take.
scottzg
I always thought that cutting a couple walls out of the rear tool shelf over the spare tire would make an excellent spot for a sub, if the area wouldnt give the sub problems due to heat soakerage.
Salvage yard for you clips and junk.
On my '84 GL I stripped the sun-wrecked carpet on the shelf and recovered the board with a good quality marine vinyl. I trimmed it a little larger than the board around the edges and used some Super 77 to stick it to the board. Then I cut some 'pie slices' into the speaker openings and dropped the speakers through the hole. Came out perfect and the board could have been easily replaced with nearly anything using the old one as a template if it were too rotted.
