please dont flame because they were expensive and i love them.
yes there is no filter on the intake and its just the maf screen. ill probaly out a nylon on it eventualy. and a funky k&n after that.
specs are 1.75 out of the turbo bumped out to 2.25 to the inter cooler and 2.5 from the other side of the turbo to the tb.
the bov now sounds like a type s from greddy. verry anoying. like a tssss tssss tssss tssss tssssssssss verry fast.
the color i should powdercoat them can be discussed in the ashtray.
im now hittin about 13-14 psi on the stock boost control.
fuel cut seems to be a problem when at max boost part throtle around 3500 rpm after being sustained for about 10 seconds. fuel cut or a bad miss. im hoping that a 255 will remedy the problem. if it doesnt im gettin a morgie fcd.
seems to pull harder but i cant tell that much yet because i havent stuck my foot in it all the way yet. i scared.
thanks to thawa for hosting.
