It's a really tight fit, but everything works fine, i didn't get any pressure drop compared to no i/c. I still have 8-9psi, and much better performance.
Before, from 3/4 to full throttle i couldn't see any difference. Now i can use that last 1/4, it really pulls hard now.
I used only one inlet to the I/C, to simplify the installation, and i don't think it hurts performance too much. I used a plate to block the other inlet, and i tapped the boost gauge fitting in it.
I shaved both the Throttle body and the i/c flange, trimmed the hood and firewall, and used a radiator hose to fit the turbo to the i/c, and that's it.
Really worth the effort and 100$can, recommend it the anyone who has a garage.
