94 Legacy RS Turbo Wagon (fixed pics/updates!)
iluvdrt
Post by iluvdrt »
dont forget the MBC so you tune higher than 8 psi LOL
98 LGT wagon auto
PNP heads, wrx 5 spd conversion, sti struts, whiteline suspension, 4/2 pots, lots more
05 impreza wgn stock
You can't tune the stock BCS?
timmy p
Post by timmy p »
Ok, so here is the scoop.
The turbo intake pipe is kinked ( i knew that) just not how bad, its kinked so bad that not enuff air can get through under boost, which caused the hose to the IC to collapse. The turbo def. has to be rotated.
So we actually had to detune the car to make it a lil more driveable, the A/F ratios were not that bad but Nat'l Speed in Wilmington, NC adjusted them a lil better.
On 2lbs ish of boost it put down 156hp and 158lbs of TQ.
i did get one run at 11lbs and got 200hp so the way the tuner figures, i should get bout 215-225 to the wheels. :wink:
Almost done!!!
iluvdrt
Post by iluvdrt »
ericem wrote:You can't tune the stock BCS?
Yes, but an MBC is easier and the boost doesnt taper or drop off as much.
98 LGT wagon auto
timmy p
Post by timmy p »
Car is now running STRONG !! just gotta get it to the dyno now for some official numbers
Almost done!!!
timmy p
Post by timmy p »
I have the Wideband installed (which i got for a steal!!) A/Rs are good TurboXS boost controller installed and set at bout 11-12lbs. may take it next weekend to get a pull done. I'll post the #s ASAP
Almost done!!!
timmy p
Post by timmy p »
Well turns out the fuel pump wasnt pumping enuff fuel, so swapped it with the one out of my RS impreza that has an STI pump and that was the prop. now its not getting enuff air which means i need to go rotated to get the kink out of the inlet pipe.
Almost done!!!
timmy p
Re: 94 Legacy RS Turbo Wagon (fixed pics/updates!)
Post by timmy p »
car is for sale needs to be tuned!! PM for more ?s
RckyMtnLegacy
Post by RckyMtnLegacy »
Updates? Did it sell?
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
