94 Legacy RS Turbo Wagon (fixed pics/updates!)
iluvdrt
Post by iluvdrt »
Timmy P bought this wagon about a month ago smoking like crazy. A short compression test showed cyl #4 was shot. After pulling the engine and heads we saw the #4 ringland melted away. The rings were OK, and so was the cyl wall. Here is where the build starts.
Car: 94 Legacy Turbo RS Wagon
Trans: 4EAT
Brakes: Stock (vented front and rear disc)
suspension: Stock with Whiteline springs
Engine: EJ22T
Our plans are to not only document and rebuild the engine, but the brakes and suspension too....all in about 2-3 months (I am deploying soon).
Here is where we are.
EJ22T bored .020"
weisco forged pistons/rings
weisco HG
ARP head studs
Toga race bearings
EJ25D Heads, flowtested and machined
EJ25D Intake manifold
Invidia uppipe
WRX TD04 (will be upgraded later)
Top Line gasket set
3" flowmaster exhaust
07 WRX TR exhaust manifold
New water pump
new t-stat
EJ25D t-belt
What we need:
STi Injectors
EJ25D seals
PP6 engine management
EJ22T t-belt tensioner
and I am sure a bunch of other stuff along the way
Here are the pics so far...
98 LGT wagon auto
PNP heads, wrx 5 spd conversion, sti struts, whiteline suspension, 4/2 pots, lots more
05 impreza wgn stock
iluvdrt
Post by iluvdrt »
EJ25D intake manifold, about to be sand blasted and painted.
EJ25D DOHC heads, resurfaced, and flowtested
new uppipe
Race bearings
HG set
Studs
Forged pistons
Gasket kit for some of the engine
98 LGT wagon auto
iluvdrt
Post by iluvdrt »
The machine work is being performed at Majestic Motorsports in J-ville, NC.
Update:
Read on to see about this place. I do not Rec them, they did not do a good job at all with the build.
98 LGT wagon auto
RJ93SS
Post by RJ93SS »
sounds very cool, don't forget the intercooler
94SS_Canada
Post by 94SS_Canada »
looks like its going to be a nice fresh clean build, I look forward to more pics.
FastRust
This is going to be a awesome build. Good to know it went to a good home.
iluvdrt
Post by iluvdrt »
RJ93SS wrote:sounds very cool, don't forget the intercooler
Almost forgot. 07 WRX. Its in the garage.
we also have 07 WRX struts for it!
ericem wrote:This is going to be a awesome build. Good to know it went to a good home.
Did this used to be yours? Tim said the guy he bought it from posted here.
98 LGT wagon auto
PhyrraM
Post by PhyrraM »
Looks like shtbxr22's old car.
You sure you don't want to toss in some Eagle rods while you are in there? The stock set leaves a lot to be desired.
You need to use the 2.5 timing belt tensioner with the DOHC heads and belt.
Otherwise, good luck.
iluvdrt
Post by iluvdrt »
93forestpearl wrote:You sure you don't want to toss in some Eagle rods while you are in there? The stock set leaves a lot to be desired.
Cool, I am glad the t-belt tensioner will work. it came new with the heads I got.
As far as rods, it was considered, but I really havent heard of anyone breaking a rod unless they are going to really push the limits. The largest turbo discussed in this build was a VF-39, and possibly a 18G. Not to much.
98 LGT wagon auto
Gotcha. Ask NICO how many EJ22T shortblocks he has grenaded, lol.
Those turbos will be pushing the limit of that rotating assembly, so good tuning is a must.
iluvdrt
Post by iluvdrt »
Now I am scared......
I also ordered some parts today. Mostly just seals and o-rings for the fuel system. I also orderd new bolts for the cams and intake. The OEM ones were looking rough.
Still on the list to buy:
Injectors
PP6
odds and ends.
98 LGT wagon auto
Don't be that scared. A friend of mine is making about 296whp on a stock 22T bottom end. He went to a good tuner though. Jorge from P&L comes up here once in a while.
iluvdrt
Post by iluvdrt »
We will probably go to National Speed in Wilmington NC, or Robbie in Fayettville. Not sure yet.
98 LGT wagon auto
Aerotech
Post by Aerotech »
I have a PP6 for you, never installed. Asking $350 w/ interface cable.
Jerry
iluvdrt
Post by iluvdrt »
Aerotech wrote:I have a PP6 for you, never installed. Asking $350 w/ interface cable.
Done, you have PM.
I will have a few more pics very soon. I should be getting some parts in soon, and I am having some sand blasted and painted.
I will also be cleaning out the heads and oil passages as well. I was thinking about just using a parts washer we have here on base. It uses a biodegradeable cleaner to clean things. I think that will work, than Ill coat everything in a nice coat of motor oil to keep it fresh and rust free.
98 LGT wagon auto
iluvdrt
Post by iluvdrt »
OK, sorry I havent been around in a while. Predeployment briefs and such.
I got the new manifold together, it looks sweet. Ill have pics this weekend. I should also be getting the block back as well with pics. Tim comes back this week, so we should be able to get the rest of the parts soon, and hopefully complete the swap by mid Nov.
Pics soon.
98 LGT wagon auto
timmy p
update
Post by timmy p »
We got the motor back yesterday and it looks great!! a few seals and some hoses and were good . We got the heads put on and cams installed, shouldn't be to long now. New pics soon.
iluvdrt
Post by iluvdrt »
UPDATES!!
I got the intake manifold completed. It now has yellow top STI injectors, and all new seals through the fuel lines.
The engine is back now. It appears to be in pretty good shape, and they did a good job cleaning it. The new pistons look great inside. They did leave the oil pick up tube loose though inside the pan :evil:
So now, the heads are on. We used copper to coat the head gaskets, and ARP studs to bolt everything together. We gave it a new water pump and thermostat as well.
The timing belt tensioner does not bolt up to the bracket, so we need the newer style bracket to accomodate the new style tensioner. Other than that she is almost ready.
98 LGT wagon auto
iluvdrt
Post by iluvdrt »
The next few pics are just for fun. We placed everything together and did a mock twin turbo set up, and a monster turbo set up. Enjoy.
98 LGT wagon auto
Nice snails there ;)
iluvdrt
Post by iluvdrt »
Were decideing which ones to use. Probably go with the TD-04.
98 LGT wagon auto
I see where you painted your valve cover(s).
94SS_Canada
AWD_addict wrote:I see where you painted your valve cover(s).
haha, good eye!
FastRust
iluvdrt
Post by iluvdrt »
ehh, why not, I mean thats why I got the rubber matting. The only prob was the amount of over spray. I didnt anticipate that, LOL.
98 LGT wagon auto
