07Evolved's '91 AWD Wagon 5MT
SiCkSTi04
Re: 07Evolved's '91 Legacy L Wagon 5MT N/A
Post by SiCkSTi04 »
tho I'm not so much of a fan of 17's on our cars. it still looks nice ::):
Those wheels look good except they do look a tad large and it makes the car quite tall.
07Evolved
Post by 07Evolved »
I agree that it does make the car look a bit taller and what not, but I think the look of the wheels blends better with the chrome door handles and the other accents of the car more so than the gold wheels. I still like the gold wheels but I need to get them powdercoated to look nice.
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
I agree. I hate gold and chrome. I'll be selling my door handles soon since I bought white ones. Just haven't put them in yet.
07Evolved
Post by 07Evolved »
kimokalihi wrote:I agree. I hate gold and chrome. I'll be selling my door handles soon since I bought white ones. Just haven't put them in yet.
Where did you get white ones? I was planning to just paint my mirrors and door handles in the near future.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
I think it was from BSOD or whatever his name is. Off his totalled white wagon facelift model.
07Evolved
Post by 07Evolved »
just bought the ej22t off of fatgc8 and i'm looking forward to a great build...my first real engine build!!
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
07Evolved
Post by 07Evolved »
Tonight I decided to start tearing down the EJ22T even though I have absolutely no experience building motors. I removed the intake manifold, the timing belt and the wheels/tensioners, and the valve covers.
I am enjoying this so far, but I do feel that this may be too overwhelming at some point for me not having nearly any of my tools out here yet in AZ and no experience building motors.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
Yup. You get in deep enough and it will definately become overwhelming if you're new to it. But it's that much more satisfying if you finish it.
07Evolved
Post by 07Evolved »
kimokalihi wrote:Yup. You get in deep enough and it will definately become overwhelming if you're new to it. But it's that much more satisfying if you finish it.
The only thing wrong with this engine was a blown head gasket but I am going to rebuild the whole thing. I am thinking I will just get it honed, but nothing else special. I just need to get the parts to do the swap. What do you think about that strategy Kimo?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
fatgc8
Post by fatgc8 »
Very nice! Now take off the oil pump,water pump,exhaust manifold. I would consider buying a 08+ sti oil pump its a 11mm pump and works a lot better then the ss oil pumps. I would also start looking into some dohc heads out of a ej20g. Give me a call if you have any questions.
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
I think it sounds like a good strategy but really I probably don't have much more experience than you, if any. If I was going to replace a blown head gasket and go through all the work I'd resurface the block and heads and have the machine shop do a valve job and maybe even get cams. Also replace the oil pump and water pump as GC8 said and the idlers, pulleys, cam seals, valve cover gaskets, bolt gaskets on the valve covers and the timing belt too.
I'd probably go DOHC too. Haha. I'd either go delta cams or DOHC but delta cams and DOHC is pretty expensive.
I'm willing to bet that after I get this car running it's going to be super easy to work on since I'll be so familiar with the whole thing.
Here are some pictures of my rebuilds if you need anything for reference
http://main.experiencetherave.com/subaru/images/ej22t/
http://main.experiencetherave.com/subar ... t_headwork
I will throw in my two cents regarding the rebuild. The first rebuild I did was alright, but I really was not as attentive to the details as I should have been. I put in new bearings, pistons/rings, and had a valve job done. However, I should have had the motor decked and the heads decked. Also, I probably should have checked the heads after they came back from the machine shop. I also should have checked the clearances on the bearings more closely.
For one reason and another.....I'm rebuilding it again. I'm paying closer attention to bearing clearances as well as piston to cyl wall clearances.
So I guess the moral of what I'm trying to say is....take a little extra time and make sure every detail is being checked and as a result, you will most likely spend a little more money....
fatgc8 wrote:I would consider buying a 08+ sti oil pump its a 11mm pump and works a lot better then the ss oil pumps.
Just curious why you say the STi pump works a lot better than the SS pump? The info in the FSM indicates the SS pump is a 10 mm pump. At 5,000 rpm pressure is 43 psi and flows about 12.42 gpm, while the relief valve is set at 85 psi.
It was my understanding that the SS pump had a higher oil pressure output since it had the oil squirters. But that may be internet hearsay.
You have any data on the STi oil pump? Did they change it in 08?
07Evolved
Post by 07Evolved »
fatgc8 wrote:Very nice! Now take off the oil pump,water pump,exhaust manifold. I would consider buying a 08+ sti oil pump its a 11mm pump and works a lot better then the ss oil pumps. I would also start looking into some dohc heads out of a ej20g. Give me a call if you have any questions.
Thanks D! I really do need to get the engine stand like you were telling me before I go any further.
So, from I gather now...I am in need of a new water pump, oil pump from 08+ STi, a Walbro fuel pump, an SS crossmember....what else?
Why the EJ20G heads? How do they compare to the EJ22T heads?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
07Evolved
Post by 07Evolved »
I'm definitely going to get a machine shop to do some work to it once I have it all apart. I have heard I need to resurface the block, get it honed, maybe new heads, and definitely the valve job. What else should I have a machine shop do? I want to build this engine right the first time so any advice would be great. I will be buying a rebuild kit which I assume includes all gaskets, seals, etc.
Is it really worth getting a new DOHC cam and EJ20G heads?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
07Evolved
Post by 07Evolved »
Legacy777 wrote:Here are some pictures of my rebuilds if you need anything for reference
Thank you Legacy...I'm in no hurry with this build. Like you said, I want to do this right the first time and make sure everything works well.
So, for the machine shop, I also need them to get the motor and heads decked?
Any other advice? LOL..I guess, what exactly do I need to get a machine shop to do?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
fatgc8
Post by fatgc8 »
All USDM turbo Subarus from 90-2007 came with a 10mm pump. In 2008 Subaru introduced the STI in dual avcs on the intake and exhaust side instead of just the avcs on the intake side found on the 2004-2007 stis. Avcs works off of oil pressure and since the 08+ sti now have it on both intake and the exhaust camshafts they upped there oil pump to a 11mm pump. Its now got a 11mm rotor in it instead of the 10mm rotor. I currently don't know the specs on the new pump but i do know that they flow a lot better then the prior pumps. A lot of Subaru engine builders are starting to use this pump simply because it works a lot better and its a lot cheaper then the Cosworth pump. I'm currently running this pump in my built 05 sti.
Engine stand is like $40 at harbor freight tools. Get one. I also got an engine hoist there but I can't remember how much it was but they were both cheap as hell and work great.
07Evolved
Post by 07Evolved »
Thanks Kimo...I will check into that. Will the 750lb engine stand work or should I get the 1000lb one?
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
crashnburn
Post by crashnburn »
750lb will work. Im watching this thread because I want to do the DOHC conversion soon.
07Evolved
Post by 07Evolved »
crashnburn wrote:750lb will work. Im watching this thread because I want to do the DOHC conversion soon.
Thanks crash...haha yeah, I will let you know how the conversion goes.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
07Evolved wrote:Thank you Legacy...I'm in no hurry with this build. Like you said, I want to do this right the first time and make sure everything works well.
I would get the motor & heads decked just to make sure the surface is 100% flat. They shouldn't have to take much off.
07Evolved wrote:Why the EJ20G heads? How do they compare to the EJ22T heads?
Check out this thread for info on swapping to the DOHC heads. It's not just a simple swap. There's other things that have to be tended to.
http://bbs.legacycentral.org/viewtopic.php?t=38247
fatgc8 wrote:All USDM turbo Subarus from 90-2007 came with a 10mm pump. In 2008 Subaru introduced the STI in dual avcs on the intake and exhaust side instead of just the avcs on the intake side found on the 2004-2007 stis. Avcs works off of oil pressure and since the 08+ sti now have it on both intake and the exhaust camshafts they upped there oil pump to a 11mm pump. Its now got a 11mm rotor in it instead of the 10mm rotor. I currently don't know the specs on the new pump but i do know that they flow a lot better then the prior pumps. A lot of Subaru engine builders are starting to use this pump simply because it works a lot better and its a lot cheaper then the Cosworth pump. I'm currently running this pump in my built 05 sti.
Thanks for the info. I'll see if I can find any specs on the 11mm pump.
