No, I've never tried the cocktail.
At this point, I'm basically convinced that each person's individual situation will dictate which oil to use.
Some people still swear by Redline, even though it didn't work for me. Some people (like Vikash) blew up a tranny with GL4 oil, while I've run GL4 several times with no ill effects.
Maybe it's because my transmission has more miles on it, maybe there's something in the shot-peened metal in the Turbo trannies that is more receptive to one oil over another...
The best suggestion I can make at this point is to just try different oils and see what works best. I do however recommend AGAINST using GL4. Like I said, I glanced at a memo written to my manager that Subaru no longer recommended using GM Synchromesh and would NOT honor any more warranty claims with it.
Grinding synchros...
so YOU'RE one of the guys who is taking all of Michigan's good Subaru parts!!!! CURSE YOU!
ha ha ha, what is SHIPPING costing you on that 2.5?
ciper wrote:Well, if I was really nice I could let you buy the 4.44 lsd i was going to get instead. I was just about to send funds.
Why does it have to be local? I was just about to have a 2.5l engine shipped from michigan to california for just under 200.....
After paging through Uncle Scotty's posting, I found something quite interesting about old cars and the coctail.
One guy wrote:
"6 months ago i put the cocktail in my 96 legacy. it made it shift awesome- almost as easy as a honda .
but gradually bearing noise developed. this is a junkyard tranny with claimed 80k miles. it did not make noise before i put the cocktail in. a subie mechanic told me today that he thinks the lightweight shockproof and synchromesh are too thin for a tranny with this much mileage. thoughts???"
Uncle Scotty replied:
"...I would likely wanna use the heavyweight shockproof and/or the 80w140 HypoyC in an older trans like that"
I read through the posts here and thought I'd swap my gearbox oil. I had in some heavy weight stuff when I ran the car in the CA heat. Here in MA all was well until the cold set in. The second gear has always crunched since I fitted the 100,000 box in. Now the crunching is worse in the cold weather. So I thought surely changing the oil can't fix it??? well it's strange because I swapped the oil for Coastal 75/90 blend yesterday and for the first time today I changed into second with no crunch! I'm not convinced yet but I've never had this happen so time will tell. Strange oil can make such a difference.
Cheers
Chris
Rally Legacy AWD #370 gone! Rally Suzuki swift GTI N1 #370 parted out. Now Mini Cooper #370 with STI suspension in Costa Rica
Chris
Well after since changing the oil the box is like new! I read the posts and thought yeah right! but I can't believe just changing the oil could make such a difference. Now I'm a happy camper as I don't have swap the box.
Cheers
Chris
Chris
