91/94 turbo Legacy parts, almost anything you need
the_watts10
fenders and hood
what color is the car if purple could ibuy the hood and fenders hood only turbo car!!!
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
Re: fenders and hood
hmmmmmm...........the_watts10 wrote:what color is the car if purple could ibuy the hood and fenders hood only turbo car!!!
wasn't there a thread describing this sort of recurring problem?
the_watts10
jimforsyth
subaru legacy turbo
Any auto trans parts?
Looking for the trans,(93),, rear clutch/differential pack. The inner basket in particular,, I have a pic if you need a reference
Regards
Ian
subaru.legacy.turbo@gmail.com
Regards
Ian
93 legacy auto
93 Legacy turbo 2.0
97 SVX slotted/drilled rotors Ceramic pads
93 Legacy turbo 2.0
IronMonkeyL255
Crashsector
I just need one ECU connector for any Legacy... I need to salvage the pins to add turbo sensors to my N/A computer. Doesn't matter which plug... just as long as it has at least 5 of the "small" pins in it.
Think you can help?
--Andy
Think you can help?
--Andy
2005 Impreza 2.5RS. Traded :(
1991 Legacy L w/1994 EJ22T, 16G, WRX 5MT. Sold :(
1993 Legacy L AWD 5MT, 153k miles and many, many more to go.
2008 Legacy 2.5i Limited
You need the pins out of the ECU itself, not just the male ends from the harness, correct? If this is the case there my be someone out there who has a fryed ECU they can cut up. I will put you in contact with someone I just sold an ecu to, maybe he no longer needs the old one. I will also look through my box-o-harness-tidbits, maybe I can match up something for you.
the_watts10
Legacy Rally Guy
I was wondering about the right rear ABS sensor and some sheet metal.
I'd pay for the full pair of front fenders but all I need is from just above the molding down.... my front fneders bottoms are just a little rusty and I figured I'll seam them to my fenders, just behind the molding... A little plug welding, primer and paint and I'm good!
ABS sensors are a bit of a pain, but a sawzall would definitely save me on shipping.. ^^ Unless the fenders like perfect!
Let me know what it'd be for em thanks!
shipping to 63532
shipping to 63532
man, you need to just order a fender from a company who sells them... I just bought one through a friend who has a body shop in canada, and the fenders for our legacies are not that expensive...
www.crosscanadaparts.com is where my fender is coming from, just for reference.
All out of BPV's
No fenders but have a few hoods. Nothing in purple, the closed I have is a turbo 92/94 winestone, faded pretty bad.
I may have the good section of fender from the molding down, I will have to take a look.
I have some ABS sensors, I will look to see which ones I have when I get to the shop today.
I just looked at the site for the new fenders, someone should buy a ton of the 90-91 and put them in a safe place for the future!!!!
I have the foglight blank, PM coming on that.
