Page 58 of 131
Posted: Mon Aug 13, 2012 9:04 pm
by Danny-G
Gonna wash the wagon, put the stero and digi compass from the sedan in the wagon, and try to set up some sort of long distance light kit for the wagon as well. I might need something like that for I-90.
Posted: Mon Aug 13, 2012 11:26 pm
by Thesubielover
Just swapped in the silicone 90 for the POS hot water rubber 90 I was using. Do me a favor, and never buy a hot water heater 90 or the turbo inlet. You'll do like I do an choke more then half of the power band and then realize "oh, i should just have ordered a silicone 90" lol.
Posted: Tue Aug 14, 2012 12:22 am
by cj91legss
No bueno
Posted: Tue Aug 14, 2012 5:47 am
by Danny-G
Didn't wash the wagon but I did get the stero and digi compass installed in it along with the amp and two subs I have and I got rid of the wind noise by simply clamping the mirror mounts together for a few seconds. So much quieter in the car now, only need the stero at ten instead on fifteen. I don't think I'm gonna make a light kit for the wagon, the headlights are actually pretty decent with 100/55w headlight bulbs.
Posted: Tue Aug 14, 2012 12:22 pm
by SWRT
What color will it be?
Mine's that same green color. I'm not a huge
fan of it.
Posted: Tue Aug 14, 2012 6:43 pm
by Danny-G
Paint the door handles at the same time!
Posted: Wed Aug 15, 2012 2:58 pm
by silver03
The paint will be the same color. I dont want to have the jams and engine bay resprayed.
Posted: Wed Aug 15, 2012 6:17 pm
by Dominator
Here's my time slip from last weekend.
Posted: Thu Aug 16, 2012 3:54 pm
by Thesubielover
What r u running turbo/engine wise for you 1/4 mile time?
Posted: Thu Aug 16, 2012 5:53 pm
by Dominator
Just stock configuration.
Stock block and heads, VF-11, non-intercooled, 4EAT, full leather interior, 90 octane...
I wanted a baseline to compare to when I switch everything over.
Soon: TD05, STI yellows, 07 Intercooler, Rob tune ECU, and other supporting mods.
Posted: Fri Aug 17, 2012 4:33 am
by cj91legss
Just washed the outside of my windows, gotta make sure i can see good on my way to wcss
Posted: Fri Aug 17, 2012 5:37 am
by mike-tracy
Did an oilchange (Rotella 10w30 - only comes in gallon bottles, so I have to buy 2 gallons every couple changes).
Put in some Subaru Extra-S in my tranny. Thanks Steven! Feels great, much better than the Walmart "Supertech" that I was using to clean all the rust and grime out (tranny was sitting for years with the drain plug open :(). I've also put the AndrewTech formula (3qt Redline lightweight shockproof, .7qt Motul) in another Subaru, and ran Redline in a high mileage toyota truck for years - and the extra-s feels as good as those. Guess I'll find out during the winter if there's any noticeable difference in gear changes or etc. Overall I'm happy, and it's as good so far as the Andrewtech/Redline while costing slightly less (if you have a hookup).
Put a 1st gen Power Steering Reservoir on my DOHC power steering pump. Thanks for the idea, Kimo. Now my hood closes all the way. :) I was reading that Josh put a spring from a turbo power steering pump, and that reduced power steering assist. How would I swap it/where is it/will it fit? I recently changed from the stock SS pump to this mid 90s DOHC Legacy pump, and the steering wheel feels ridiculously light now. Can't reuse the SS pump as the DOHC lines doesn't thread in.
Posted: Fri Aug 17, 2012 5:09 pm
by Danny-G
Drove 8.5 hours to Coeud d'Alene yesterday. Wagon made it just fine, got 22.25 mpg with going over the pass. There are some fun looking roads over here, I really want to drive those roads and have some fun but I can't really leave on my own over here. I would probably get lost lol
Posted: Fri Aug 17, 2012 6:20 pm
mike-tracy wrote:I was reading that Josh put a spring from a turbo power steering pump, and that reduced power steering assist. How would I swap it/where is it/will it fit?
I think I was going to do that, but did some research and there wasn't any difference. I still may tweak the existing spring by cutting one of the end coils off to reduce the overall force it exerts, but haven't really gotten that deep into things yet.
The spring is behind the little valve body on the discharge side of the pump. If you remove that big hex nut thing on the discharge side and pull the little valving out, the spring will be behind there.
Posted: Sat Aug 18, 2012 5:00 am
by randomiam
Well. Installed the replacement passenger fender.. Its a slight upgrade over the previous one as the frontend looks a little bit better.
Driver side CV axle was replaced.. Never realized how easy it was on these cars. Click click click, goodbye.
Posted: Sat Aug 18, 2012 5:45 am
by mike-tracy
Thanks Josh, I'll play around with my spares. If not the spring, what would make the SS pump provide less power assist, and how do I make my DOHC pump do the same?
Posted: Sun Aug 19, 2012 9:37 pm
I think the spring should do it. I'd like to take apart one of the newer pumps with the electrical connection. I think it does something in there to reduce assist at speed, but increases assist at parking speeds.
Do you have any spare springs you'd be willing to part with?
Posted: Mon Aug 20, 2012 5:39 am
by mike-tracy
Legacy777 wrote:I think the spring should do it. I'd like to take apart one of the newer pumps with the electrical connection. I think it does something in there to reduce assist at speed, but increases assist at parking speeds.
Sorry Josh, by spares, I mean my car's original 91 SS PS pump, and a 2nd gen legacy SOHC pump. Blackbart'd be the man to ask - saw he was on recently. :)
Posted: Mon Aug 20, 2012 6:47 am
by oldscoobyturbo
did a front end swap to a prefacelift style on my turbo wagon. turned out really good and I customized the rad support and rebar to save time (not that it did).
adding pics
Posted: Mon Aug 20, 2012 3:41 pm
by mike-tracy
diesel devil wrote:did a front end swap to a prefacelift style on my turbo wagon. turned out really good and I customized the rad support and rebar to save time (not that it did).
OK.... you can't just post that without pictures, lol
Posted: Tue Aug 21, 2012 3:58 am
by cj91legss
+1
Posted: Tue Aug 21, 2012 3:59 am
by kimokalihi
+2
Posted: Tue Aug 21, 2012 5:09 am
by Danny-G
+3
I replaced a fog light bulb today on my wagon. Thats all.
Posted: Tue Aug 21, 2012 12:11 pm
by SWRT
Crap that turned out good :D
Nice, smooth lines. Nothing out of place.
Good job!
I prefer the 90-91 over 92-94 any day.
Been thinking of getting that front end
for my green one.
Posted: Tue Aug 21, 2012 2:16 pm
by oldscoobyturbo
if I ever do that again I'll get the rebar and the rad support had to spend 2 hours cutting it to fit
the lights and grill are not perfectly even but very close
