SubiePrice88
Post by SubiePrice88 »
Just thought It would be cool to hear what people are doing to their subies "today"
Kind of share whats going on.
Today I replaced the fuse for the main fan in my 93 wagon.
And right now Im waiting for the coolant to drain in my 92 SS so I can pull the radiator and see how bad the deer smashed it and fix the fan shrouds.
Also replaced the Coolant Temp. Sensor in my 91 SS. It starts Everytime Now!!! :-D
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
magicmike
Post by magicmike »
I took a rats nest out of my G35 cabin filter today! Not a subi but still applies!
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
I ordered gaskets for my throttle body spacer that I'm making to allow me to mount my EJ22T throttle body onto my 97 forester JDM intake upside down.
I also ordered the bolt and sleeve that bolts the shifter to the shift linkage.
Tonight when I go to my parents house I'll probably work on cutting the spacer out and filing it down smooth.
Maybe I'll heatwrap my exhaust manifold too!
BSOD2600
Post by BSOD2600 »
Finally bought another set of 2005 WRX wheels (after wrecking my old ones). Now to buy the tires and sell the extra wheels...
heh, think anyone will want a set of RE92 tires? :P
'11 WRX Limited
'94 TW | R.I.P.
Aerotech
Post by Aerotech »
Pushed it 1/4 mile after the transmission finally went tits-up. :(
Jerry
replaced the bulbs for my cruise and defrost :)
Buffman
Post by Buffman »
I redid a couple of the underhood grounds that were all corrodded. Also sounds like I might have to thin the oil mix I made up out as I had some lifter noise today on startup when it was fairly cool outside.. Guess I need 3 quarts of 5w20 to 2 quarts of 15w50 :)
1992 Legacy LS Special Wagon..
brand
Post by brand »
I found a local guy parting out a 91 that happens to be the correct color code. Goodbye, rusty fenders and dented trunk lid!
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
biggreen96
Post by biggreen96 »
Lit the sedan on fire!
Not on purpose!
Was putting these on:
asc_up
Post by asc_up »
Changed my tranny and rear differential fluid.
changed my knock sensor and wires which no difference except maybe the wires making it a bit smoother, and later swapped back to the stock coil pack and noticed the car seemed a bit quicker!
gijonas
Post by gijonas »
Spooled up the turbo big time,Enjoyed owning it.
GUNZ
Post by GUNZ »
Cleaned my IACV, replaced the air filter (pureone since it was just 3 bucks more than the regular $9 purolater filter) and found out my PVC is completely clogged (It wouldn't clean up, so i'm going to get a new one tomorrow after golfing).
Oh and of course after the work I had to take it for a "Test Drive".
Ed
91 Legacy L Wagon
03 Legacy L SE Sedan
07 Toyota Tundra 4X4
Post by SubaruNation »
karate chopped it in the face then promptly said im sorry i love you :o
magicmike
Post by magicmike »
SubaruNation wrote:karate chopped it in the face then promptly said im sorry i love you :o
lmao That litteraly sums up how I feel about this wagon! :)
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Imprezive
Post by Imprezive »
It sat and did not start all day. But I am buying a FCD for it so I can go tune it @15psi :D
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
DLC
Post by DLC »
I installed the simple, non-"torque box", intake on the BK4 last night. Lots more sound (more like the Cobb), and the intake hum is far quieter. I like.
Legacy Central
smh0101
Post by smh0101 »
Cleaned air filter, Cleaned MAF and houseing, Painted part of my intake, Removed my charcoal canister, cleaned the inside of the car
Rust converter dried, I zinc coated the insides of the front and rear frame rails, front inner body, and misc. spots on the tailgate that the window trim had been partially hiding.
Post by entirelyturbo »
Remembered I still have it. :?
*Formerly DerFahrer*
N1446
Post by N1446 »
tested a paint color on the body and found the color is too white for the car - pearl white duplicolor is NOT the same as 91 SS pearl white :lol:
- repaired a nasty fuel line , verified the radiator fans turn on properly
- picked up a fog light switch from the boneyard and front sidemarker lights
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
subytech
Post by subytech »
tore down the old motor to just a shortblock (bad bearrings), cleand the heads and such then went to the junkyard and took a shortblock out of a 91 wagon with 170k miles...with no plyers, cutters, 22mm, engine hoist, or alot of other things a guy who works on cars for a living should have rememberd to take to the junk yard lol. We got the head bolts out using a 6" 3/8th drive ratchet and using the coolant crossover pipe as a cheeter pipe! It was quite an interesting day lol. :smt042
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
impreza_GC8
Post by impreza_GC8 »
Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
Imprezive
Post by Imprezive »
Carved a prototype hood scoop out of high density wall insulation, will be laying some fiberglass on it next week :D
Oh and I bought my FCD... So soon I will get some injectors and be romping around with more powah.
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
magicmike
Post by magicmike »
impreza_GC8 wrote:Diagnosed a bad injector and now I have to park the car while I try to find a set of JDM sidefeed 440cc injectors. I'm thinking about just using stock EJ22T injectors. I'm only running 11psi of boost out of a VF8, but I don't know if the stock injectors can handle that.
I thought the stock fuel system was good for 16 psi? Someone correct me if I'm wrong.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
