Page 59 of 131
Posted: Tue Aug 21, 2012 5:20 pm
by Dominator
Looks really good. That's the front end that I have, so of course I like it better than the other ones. I hate how yellow our headlights get. I cleared mine over the winter, and one of them needs it again. I can't wait to do a retrofit on this car. Yellowed fluted plastic will be gone.
Posted: Wed Aug 22, 2012 12:31 pm
by SWRT
Yeah, you can see through the other pictures, but
man...turned out good :D You kept the bumper and
made it pretty freakin close. Impressive.
Retrofit from what?
Posted: Sun Aug 26, 2012 2:18 am
by oldscoobyturbo
I installed an 04-07 wrx/sti replica lip. Looks similar to a chargespeed type 1
Posted: Mon Aug 27, 2012 2:44 am
by Grayguy
Finally got the new suspension in the leggy, eibach springs on 04' STI struts with 1/2" butt spacers in the rear. Its pretty much the perfect stance!
Posted: Mon Aug 27, 2012 6:27 am
by mike-tracy
put an MSD coil on a bracket where the AC compressor would go. Also grabbed MSD custom wires. Such a PIA to make! Car seems to rev faster and has more power off boost. Was it the coil, or was it the fact that I swapped out old ass plugwires and coilpack for fresh ones? Either way I'm happy.
Posted: Wed Aug 29, 2012 6:38 am
by Danny-G
Got a replacement crank pully and key from the junkyard today, from a '95 L. Get home and the timing gear took two hours to ger off and it broke during the process. Great. Now I gotta go back tomorrow and get that too, and I had it in my hand but figured I could use mine again. I had to use a dremel and cut the key up on my sedan, and that wasn't the hard part. It seemed like the timing gear was epoxied to the crank considering that I had to use wedges to take it off. What a pain in the ass.
Posted: Wed Aug 29, 2012 6:41 am
by kimokalihi
I like diesel's wagon. I like the wheels a lot but it would look better if the front were lower.
Posted: Wed Aug 29, 2012 5:45 pm
by Dominator
I picked up another Legacy last night. It's a 91 NA Wagon. Fully loaded, sunroof, power everything, it could be nice. But there were dogs in this car something fierce. Interior is all chewed up, smells like nasty wet dog. It needs a deep cleaning for sure. I might actually swap the whole interior out of my turbo wagon into this one. Mechanically I'm thinking a rear diff and a clutch, front seatbelts need replacing too. Definitely some new struts toward the top of the list, it's like driving on a waterbed.
Anyone have good luck with the Raceland coilovers. I know their stigma over on NASIOC, but something cheap is what I'm looking for. I'd like to lower the stance a bit and make it look good.
Posted: Wed Aug 29, 2012 9:14 pm
by cj91legss
For just a DD they would be fine.
Posted: Thu Aug 30, 2012 12:33 pm
by SWRT
diesel devil wrote:I installed a wrx front lip. Did a bit of painting etc.. pics tomorrow after the local big summer meet at Subaru Canada HQ
That thing looks mean. I like that lip too :D
Didnt know they'd fit. No cutting involved?
Posted: Thu Aug 30, 2012 1:34 pm
by oldscoobyturbo
i only cut the ends to fit about 1.5" off each side
Posted: Thu Aug 30, 2012 10:06 pm
by sqc151
nice stance.
whats the wheel specs and tire size?
Posted: Thu Aug 30, 2012 10:19 pm
by oldscoobyturbo
custom made stock 16" steelies widened to 9"
tires are 225/50/16 yokohama s drives
I'm going to slam it once I can get new collars these ones are frozen solid
Posted: Fri Aug 31, 2012 12:14 pm
by SWRT
Looks slick, man. And custom made rims?
Posted: Fri Aug 31, 2012 5:10 pm
by sqc151
What's the offset? Do they clear the wrx 4/2 pots brakes?
Posted: Fri Aug 31, 2012 5:15 pm
by oldscoobyturbo
I never measued the offset but they clear my willwood 4 pots just fine
Posted: Fri Aug 31, 2012 11:10 pm
by sqc151
those steelies look better than most aftermarket wheels.
Posted: Sat Sep 01, 2012 3:15 am
by cj91legss
I agree... They look awesome.
Posted: Sat Sep 01, 2012 7:46 am
by Thesubielover
diesel devil wrote:I never measued the offset but they clear my willwood 4 pots just fine
What year lip is that?
Posted: Wed Sep 05, 2012 12:39 am
by randomiam
Changed oil/fuel filter/air filter.. Maybe swapping out my current power steering pump soon. Basic stuff I'm getting out of the way before a decent trek out of state in the wagon-- Performed admirably hauling my mattress and canoe the other day.
Also, cleannnnned out the car.
Posted: Wed Sep 05, 2012 1:02 am
by alexandermf
Well after starting at 10am and ending at 2am we got a lot done:
TD04 swap
Invidia v2 dp
Invidia q300 catback
Sti motor mounts
Replaced all four struts, springs
Replaced all pads and rotors
Upgraded coolant tank and relocation of many hoses
New spark plugs
Valve cover gaskets
Oil change, coolant flush
Manual boost controller
It's sleepin better than ever :P
Sent from your bathroom closet
Posted: Thu Sep 06, 2012 10:18 pm
by originalcyn
Monday - Mike and I went to various Pick and Pulls and grabbed a front and rear sways
Wednesday - Test fitted the front sway
Thursday - Sways sent to be powder coated
Posted: Fri Sep 14, 2012 7:26 pm
by originalcyn
Got my sways back. Hopefully they'll be easy to install. Should be next Friday.
Posted: Sat Sep 15, 2012 2:44 am
by SILINC3R
Sarted prep work on the hood of the 90 and would show pics but photobucket is being dumb. Tired of looking at the peeling clear coat so I am painting the hood, roof, and the trunck black to give it that tuner/track look. On the trunck I am going to give it the SVX two tone look.
Posted: Sat Sep 15, 2012 6:00 am
by cj91legss
Looks good man
