Page 70 of 131
Posted: Sun Dec 16, 2012 4:57 am
by randomiam
Got bored earlier and did the power mode switch with a nifty switch to the left of my wiper. Not super impressed with the mod so far but it probably doesn't help that I'm already such a lead foot.
Posted: Mon Dec 17, 2012 7:25 pm
I spent about 8 hours on Friday, 12+ hours on Saturday, and another 6 hours on Sunday getting the six speed in the car, new rear diff bushings installed, and the car back on the ground. I've still got to do the electrical work, but overall, it's coming along pretty well.
I have to say though, it really gets old crawling under the car so much to do all that work. I've got lots of bumps & bruises, and sore muscles.
Also....your tip of the day when mating a transmission & engine....make sure to spin the engine a little bit so the clutch splines align properly with the trans input splines.
Posted: Tue Dec 18, 2012 2:51 am
by cj91legss
Legacy777 wrote:Also....your tip of the day when mating a transmission & engine....make sure to spin the engine a little bit so the clutch splines align properly with the trans input splines.
When I did my first 5 speed conversion, I encountered this problem. And believe me, there was a lot of scratching the head and thinking...
And we're talking about the head on your neck guys... In case any of you dirty minded fellows are laughing...
Posted: Tue Dec 18, 2012 7:48 am
by Thesubielover
Started the girl at the dealer when they got the battery in and the wiring for the pos and neg terminals. Car started the first time! Tech said there was no water or metal in the oil when they were changing it.
Posted: Thu Dec 20, 2012 8:05 pm
by SUBYLUV871
i yelled at my suby today. its poppin out of 4th gear. grrrr
Posted: Thu Dec 20, 2012 8:55 pm
by cj91legss
Oh that's no bueno
Posted: Thu Dec 20, 2012 11:26 pm
by Someperson
no no bueno
Posted: Fri Dec 21, 2012 2:28 am
by cj91legss
My experiences with a transmission popping out of gear are bad bearings inside or a F*CKED clutch Any Sound coming from the bell-housing area?
Posted: Fri Dec 21, 2012 2:36 am
by randomiam
Went through my front brakes on the wagon.. Having done this on other cars its easy to forget how easy our cars are to work on.
Posted: Fri Dec 21, 2012 2:51 am
by Someperson
ford tauruses SUCK!!!!!!! especially 97-00...... so inconvenient....
Posted: Fri Dec 21, 2012 5:46 am
by rallyak
Just picked up 91L wagon, going to strip it. Has some odd parts like manual windows.
Posted: Fri Dec 21, 2012 7:48 pm
by SUBYLUV871
cj91legss wrote:My experiences with a transmission popping out of gear are bad bearings inside or a F*CKED clutch Any Sound coming from the bell-housing area?
i put a new clutch in about 3 monthes ago but no noise that i can tell . it was doing great till the other day now it does it almost every time im in forth gear and let off the gas. most signs are pointing to syncros or just a worn out trans with 230k
Posted: Sun Dec 23, 2012 9:31 pm
I just pulled the dash out of my car....like less than 5 minutes ago. Probably the biggest pain in the butt was all the extra wiring I have added over the years! While I'm working on adding the newest wiring I'll probably try and clean things up a bit.
Now it's time for food, my belly is hungry!
Posted: Sun Dec 23, 2012 10:27 pm
by kimokalihi
Was it your first time removing your dash? I remember that being an intimidating job the first time. I've done it probably 5 or 6 times now though. Always cut up my hands doing it.
Posted: Tue Dec 25, 2012 5:48 am
Yeah, first time removing the dash. Honestly, it wasn't as bad as I've heard or expected....and yes I cut up my hands a bit too.
Here are pictures of the dash removal & wiring mess.
http://main.experiencetherave.com/subar ... spdswap/18
Posted: Wed Dec 26, 2012 4:59 am
by Thesubielover
Replaced knock sensor, no improvement. From what I have been reading all over the internet, the o2 sensor needs to be checked. What o2 sensors can i use on the ej22t?
Posted: Thu Dec 27, 2012 2:29 am
by Thesubielover
So family is paying for diagnostic on the girl. I have a during feeling its the map sensor. After soaking with another forum member who had identical issues.
Posted: Thu Dec 27, 2012 9:41 pm
by CAV3MAN227
-Christmas present from a friend:
-Cant wait for it to warm up so I can put these on!
-Joe
Posted: Thu Dec 27, 2012 11:58 pm
by oldscoobyturbo
removed the front lip to save it from the deep snow
had a fun time last night and today playing in the snow too poor front lip
Posted: Sun Dec 30, 2012 5:38 am
by Corifto
Posted: Sun Dec 30, 2012 11:29 am
by robertpaige
Installed an Autometer Boost Gauge tonight and wired it all up. A hefty 6lbs of boost on a blown out VF11
Posted: Tue Jan 01, 2013 9:13 pm
by oldscoobyturbo
built a hybrid seat using a 2002 wrx seat and the stock legacy base. I bolted up the upper without any modifications.
The base only required some trimming of the cover hooks and cutting a hole for the height adjuster.
Posted: Wed Jan 02, 2013 3:07 am
by sqc151
i the wife and i went out today. went to some dealers and ended up test driving this thing. pretty cool, but id get the limited sport trd.
then came home and changed the oil on the 92tw.
(checkin to make sure no leaks with the new sti pan and killer b pickup, and makin sure the group n mount and bracket are doing well)
Posted: Wed Jan 02, 2013 5:23 am
by prodrive
CAV3MAN227 wrote:-Christmas present from a friend:
-Joe
Where did you get that from?
Posted: Wed Jan 02, 2013 7:06 am
by CAV3MAN227
-I got it from a friend for Christmas. I'll ask him where he got them and get back to you. I do know they came from Australia.
-Joe
