The dyno plots can be a little confusing, especially when there are more parameters being plotted. I've tried to label the plots as best I can, but if you have questions let me know.
All the new dyno plots can be found here in my normal image gallery.
One of the plots shows the HP & torque with and without the SAE J1349 correction factor. Here is a little more information on the SAE J1349 correction factor.
Also, I've listed all the dyno plots below. (click image for hi-res version)
HP Test Results Summary
255 hp & 306 ft-lbs at the wheels
New Motor & Tune vs. Old Motor & Tune
New Motor & Tune vs. Old Motor & Tune (with and w/o SAE corrrection)
Josh's 1990 Legacy vs. 2002 Stock WRX
Josh's 1990 Legacy vs. 2006 Stock WRX
Josh's 1990 Legacy vs. 2006 Stock STi
Josh's 1990 Legacy vs. 2008 FLi Stage 1 STi
Josh's 1990 Legacy vs. Rod's 1992 Unichipped & Turbo'd Legacy
