CAV3MAN227
Post by CAV3MAN227 »
prodrive wrote:Where did you get that from?
-My friend told me he got them from a guy on the RS Liberty Club who is re-making them. Screen name = likenother (Matt). Apparently there is a big waiting list. Hope that helps.
-Joe
Someperson
Post by Someperson »
pulled the 93 fwd 5mt yesterday, was a shit job... and scrapped the entire exhaust
93 Winestone TW project
randomiam
Post by randomiam »
boost gauge hooked back up.. Might look for something backlit; Took apart the BOV as it was locked shut, cleaned it up a bit and its working again. PSHHHHHH
I think a factory bpv is needed..
Subaru-less
I played with relays and put new mats in the Impreza
randomiam
Post by randomiam »
Car starts with a working key now-- WOOHOO. I bought a steering column assembly with key & went beastmode on the security bolts.
Swapped on some slightly less white retarded looking phone dial wheels & did a quick respray of the calipers to remove the godawful white shit.
Bought a WRX BPV but I'm waiting to sort out the adapter business.
Subaru-less
Someperson
Pulled f and r bumpers an awd 5mt and the whole rear end out of my 94 GT for use in the 93 fwd NA cause sadly the 94 is too rotted to save... Will post pics later. Pulled 2 wagon tails first time no breakage. Heat gun and plastic pry bars ftw
northcoast
Post by northcoast »
Replaced motor mounts that were sheared in half. Next is the knock sensor wire. Final emissions testing this month. Hopefully it will pass.
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
turbo970
Post by turbo970 »
i had a dream i drove my subie
Someperson
how the hell do you shear off motor mounts???
Dominator
Post by Dominator »
Someperson wrote:how the hell do you shear off motor mounts???
Yeeee Haaawwwwww!!!!!!!!!!!!!!
northcoast
Pretty close but not as much air this time. I think I bounced around on the way out of this section.
I was lucky. My buddy lost his motor mounts, exhaust, and a chunk of his head.
This method also works to remove door trim!
Dominator
Post by Dominator »
Ha ha ha!!! Wow. That's awesome.
Someperson
how was the chunk of head lost?
northcoast
No idea but with as much force as he hit that rock I'm surprised that's all that happened. Here's what it looked like from the back side. He lost his tranny mount too.
So glad I have a skid plate... not that it would have helped much if it hit it at that same angle.
keithmoilanen
Post by keithmoilanen »
Grr my wagon is waiting to see some trails after I lifted it last year. So sad...
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
jamal
Vendor
Vendor
Post by jamal »
It was a couple days ago but snow tires and ski racks are on:
I continued working on the wiring.....it is tedious! I got the alarm back in the car....the original installer fucked up so much...it's really quite amazing it actually worked. I made a list of the remaining connections that need to get hooked up, and am hoping to take off on Friday this week so I've got two full days to work on it.
keithmoilanen
good luck josh hope all goes well
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Installed a z4 ecu in place of my 3b. Wow. :)
That z4 is going to blow the doors off Lots of cars when i put it in my car.
Danny-G
Post by Danny-G »
I'm planning a junkyard run tomorrow to get a full set of 76,805 mile outback spring/ strut assemblies. Its time to replace my almost frozen stock suspension with 268,605 miles on it.
Danny
keithmoilanen wrote:good luck josh hope all goes well
Thanks!
turbo970
Post by turbo970 »
mike-tracy wrote:Installed a z4 ecu in place of my 3b. Wow. :)
how good are these z4's for our subies?
I liked it :-).
turbo970
Post by turbo970 »
and if i was able to find one what all would i have to do to make it work in my car which is supposed to be done in a week
