Page 78 of 131
Posted: Mon Apr 15, 2013 8:16 pm
by James614
Replaced my lift gate handle with a much less rusty one from an Outback. Also "repaired" the lower interior panel of the lift gate, as it had a huge crack in it. I actually got the idea from guys who intentionally cut their bumpers then zip tie them together for show
Posted: Mon Apr 15, 2013 10:38 pm
by originalcyn
Grille v3.0
Posted: Mon Apr 15, 2013 11:13 pm
by cj91legss
originalcyn wrote:Grille v3.0
Posted: Mon Apr 15, 2013 11:28 pm
by originalcyn
CJ, it's time for a new grille! What of it? lol.
Posted: Mon Apr 15, 2013 11:30 pm
by cj91legss
Have you done it yet or are you planning on making a new grille?
Posted: Mon Apr 15, 2013 11:36 pm
by originalcyn
The process has started, but it's not finished.
Posted: Mon Apr 15, 2013 11:38 pm
by cj91legss
Posted: Mon Apr 15, 2013 11:48 pm
by originalcyn
Haha! Nice! Did you decide to put a scoop back on? GASP!
Posted: Tue Apr 16, 2013 12:14 am
by cj91legss
Yes I did.
Posted: Tue Apr 16, 2013 1:47 am
by CAV3MAN227
-cj91legss, do you plan on doing a write-up on what you did for the front end swap? I'm setting a goal for myself to do this, this summer.
-Could I also get some more shots of your car from the side, like around where the fender meets the door?
-Joe
Posted: Tue Apr 16, 2013 1:01 pm
by cj91legss
I'll snag some more pics and throw them in my build.
Posted: Tue Apr 16, 2013 10:45 pm
by James614
FINALLY found a 1sr Gen shell in a JY down here! Got myself all the trim and the liner for pass fender, which has been bare since I replaced it 5 years ago.
Posted: Thu Apr 18, 2013 10:17 pm
by dillonr92
I was wondering why you changed from the specture intake back to desnorked air box? Is thete any diffetence? Is it better? I feed my intake air from my lower grille with a dryer tube(ghetto style) .i also haveba ok heat shield built but it dosnt box off the cone the tops still open. My question i guess is if i box my intake in at the hole in the fender and do the coffe mug mod will that be good or should i just put the desnorked box back in and do the mod? And the air box opening to the fender well hole is only like 2" as the cone allows the MAF to breath 3" of air should i open the hole in the box some? I meant to post to the thred not pm you alexandermf. New to the bbs amd android internet sucks
Posted: Thu Apr 18, 2013 10:31 pm
by CAV3MAN227
-Been having a CEL on, code 41, and cant figure out why. Came up on a spare o2 sensor to swap to see if it might be the issue. The plug heads were different sizes so wasn't able to rule out the o2 yet. Ruled out the MAF by swapping it with one that I knew worked so cant be that. Out of this, I didn't know our cars would run without an o2 sensor, weird!
-Joe
Posted: Fri Apr 19, 2013 1:18 am
by Someperson
picked apart a 92 winestone SS for trim and headliner WOO! got a nice supple intake elbow out of the deal and corners, headlights, visors, and some other stuff all for $100!
Posted: Fri Apr 19, 2013 5:41 pm
by dillonr92
Caveman.... Do you know what the 41 code is or are you doing process of elimination?
Posted: Fri Apr 19, 2013 6:32 pm
by CAV3MAN227
dillonr92 wrote:Caveman.... Do you know what the 41 code is or are you doing process of elimination?
- I know what it is, A/F learning control, faulty learning control function. What I don't know is how to get it fixed. So I just started with the basics, MAF and o2 sensor, so yea like you said, process of elimination. If you have any ideas, I would be more than happy to hear them. Thanks.
-Joe
Posted: Fri Apr 19, 2013 6:36 pm
by dillonr92
I took my intake cone and heatshield off last night and put the stock desnorked air box back on. I also ran into some bad pcv lines and oil lines. Also some vac leaks hopefully have enough $ this weekend to get new clamps and hoses . Gonna finish taking my A/c system out,, Anyone done this recently? Maybe tell me how to pull the condenser radiator thing,,, infront of the actual radiator. . I was also wondering if a 90 l metal MAF is the same as the stock ss one. I am using one now but cant tell if it helped as i have vac leaks.....
Posted: Fri Apr 19, 2013 6:49 pm
by alexandermf
Dylan-yes its the same I'm using a 90l metal maf on mine, they came on the manuals. Also I would reduce that dryer tube from your foglight opening to the box because depending on where you live, getting water up in there's is a bbaaaaddd idea. Mine maybe is 8" coming into the fender, not all the way down to opening
Posted: Fri Apr 19, 2013 7:08 pm
by dillonr92
I also have the code 41 .. 21...22....31... try testing your ecM.... Its controls the AFR readings or somthing like that
Posted: Fri Apr 19, 2013 7:16 pm
by CAV3MAN227
-Never heard of a 'ecM'. Could you be a little more specific please?
-Joe
Posted: Fri Apr 19, 2013 7:24 pm
by dillonr92
Me either but i looked up code 41 in the leggy book it said lean mix...... AFr.....goto chapter 4 the only thing i found for AFR or related was a section i about the ecM idk ill read it all on lunch qnd get back to you.
Posted: Fri Apr 19, 2013 8:31 pm
by cj91legss
Check out my last thread on my build thread
here
Posted: Fri Apr 19, 2013 8:44 pm
by dillonr92
Thanks alex. And i am gonna completely get rid of ithe tube completly cuz after a month of using it with my bright red cone . It is now half black and half tinge red. ...
Posted: Fri Apr 19, 2013 10:29 pm
by dillonr92
Sweet ill keep useing that MAF then. i looked at that ecM thimg again and i just took pics.......
