robertpaige
Post by robertpaige »
Did a little detail clean up.
Found out tonight that before I traded my car back for my white SS yesterday, the guy was redlining it at a car meet for loudest exhaust. Checked the oil after we traded and the dipstick was dry. Literally praying that the motor is going to be okay. Seems to be running fine, doesn't make like any ticking or anything.
Someperson
Post by Someperson »
bought all the parts!
93 Winestone TW project
CAV3MAN227
Post by CAV3MAN227 »
-Sea foamed the car. Made a video on how I did it. Tutorial coming soon.
-Joe
Dominator
Post by Dominator »
It's finally warming up in Alaska. I had an opportunity to wash the car since it was a nice evening after work tonight. It's the first good carwash of the season. Nice and shiny! New wheels for the summer too. Its great to get rid of the winter grime, but now I can see the chips, dings and a new dent :|
dillonr92
Post by dillonr92 »
Wheel wells gone. Need a new one.
92 SS winestone red. td04 - FMIC. RWD 5 spd swap/LSD.dead...
94 LEGACY GT RAISED ROOF WAGON, fozzy lift hydro clutch/91SS 5speed/VLSD..#5.NEW FuLL DRiFT SLuT 93SS winestone,RS 5speed RWD. Welded rear, td04, fmic, 17x9 +20
CAV3MAN227
-Cleaned the k&n filter, after off roading, the filter turned an orange color!
-Joe
James614
Post by James614 »
dillonr92 wrote:Noticed my wheel well was missing...... Has anyone had one come off while driving.. Cuz i didnt hear or notice anything. Kinda wondering if some one stole it cuz there was no other damage just some scuffing on the strut
They are very flimsy. If the fasteners were already breaking/coming off, I wouldn't be surprised if you couldn't hear it over the sound of driving on gravel or a series of bumps/broken pavement.
randomiam
Post by randomiam »
Recalibrated my wideband sensor and changed its power source.
..need more boost..
Subaru-less
turbo970
Post by turbo970 »
changed my coolant temp sensor the old one was crusty and nasty looking. and after that i hooked up my grimmspeed mbc and my idle dropped to 900 rpms. i'm happy with that for now lol
94EJ22
Post by 94EJ22 »
Installed a Perrin plate delete and cleaned my interior up.
1994 Subaru Legacy L Winestone Pearl
James614
Post by James614 »
Got brand spanking new "Subaru" and "Turbo 4WD" badges for my liftgate :D
turbo970
Post by turbo970 »
installed my turbo smart plumb back bpv and had to get a new O2 bung put in my down pipe
randomiam
Post by randomiam »
Was messing around and temporarily tried out the launch control feature built in with the MSD-DIS 2.. Not nearly as loud as I expected and I was reluctant to try it on wet pavement.
Subaru-less
I got the receiver wiring finished and got it back in the car. I also have the seats back in, put the battery back in the car, and ran some tests/checks on all the wiring changes I made.
Just an FYI, the dome light door trigger does not work if the gauge cluster is not in the car. I ran across this today....I was like....WTF doesn't the dome light work now.....I looked at the wiring diagram and then realized everything went through the gauge cluster. I plugged the gauge cluster in and it works. :)
turbo970
Post by turbo970 »
found these in my fresh rebuild. wonder if this is the reason i'm running a tad rich. also installed my diamond coil pack
CAV3MAN227
-Plasti dipped my side trim:
-Joe
91legacyawdturbo
Post by 91legacyawdturbo »
Washed the legacy. Replaced the passanger rear hub, wheel bearing was thumping. Put the 2.5rs side skirts, and installed a radio on the impreza coupe.
2002 wrx sport wagon
nosyt
Post by nosyt »
so i did this yesterday... and its not actually on the car yet... but got my boomba fuel rails mounted up to my ver8 sti manifold with some adapter plates. really nice kit im quite impressed. just have to wait till motor is in car to build the lines so they are all proper length
matt00rs25
Post by matt00rs25 »
Stripped three diff colors and prob 10-14 coats of paint off my rota torques. Method used:
2 gallons of brake clean
1 child saucer sled
One wheel face down in fluid
Roughly 10 min of soaking the paint was falling off and there all down to bare aluminum and ready for primer and paint
nosyt
Post by nosyt »
oh and i just painted and installed lgt wing on my daily
SUBYLUV871
Post by SUBYLUV871 »
proud new owner of a great set of gr2 struts with 1.5 loweing springs. low low miles. $200 now to mount them.
1998 legacy l wagon
1988 ford ranger prerunner (my baby
Soldered an OEM connector plug to my stereo harness... I hate it when people cut off the old plug and then do a terrible splice job. Fixed a problem I'd been having ever since I replaced my heater core (cold air leaking onto passenger feet) by aligning the "boxes" under the dash better.
mike-tracy wrote:Soldered an OEM connector plug to my stereo harness... I hate it when people cut off the old plug and then do a terrible splice job. Fixed a problem I'd been having ever since I replaced my heater core (cold air leaking onto passenger feet) by aligning the "boxes" under the dash better.
I dont understand why people do that.... the harness is less than 15 bucks
James614
Post by James614 »
I know many shops do it to compel you to go back to them to put your stock unit back in.
matt00rs25
Goldie's
